I make them several of different type ...............
1.universal one , for scriber i used HSS steel . Little tricky to scribe but it work .
2. I like this one , for scriber i used broken carbide bits .That will mark edge easy on any hardened steel . I found some topic about this one and someone there don t like it because tool mark only one line .Well NOT if you drill hole for scriber little off center .....Probably this is the only one tool which will work on pre-tapered blank .........
3.Same as number 2 but little more space between rods for really thick steel . Hole is dead center and will mark one line .........which i don t like too
4. Well , THANKS
JTknives
..................this is the one i was searching for
Easy to make even more easy to use . For scriber I used one carbide tip from circular saw........I think that this one is best from all I was found on net .It will mark line even on my 1.5mm thick 1.2519 steel
4. Well , THANKS
