Ok...
Well.
So if you saw my Bravo-1 thread, I attacked a bunch of nasty things with my Bravo-1. (Dust and sand-laden cardboard boxes.)
By the end, the edge was pretty much crap.
So... I took my 600 grit sandpaper, laid it down flat on a squishy surface (CD holder case... pleather plus some cushioning material), pushed down, and made some passes spine-first.
Now it's sharper. Passably sharp... nowhere near my normal v-beveled knives, though. It at least cuts paper, but only on a draw stroke, and not on a push.
I also notice it's developed what looks like a visible bevel line -- not a straight one, but that glistening line along the edge that says to you, on a normal sharpening job, that you need to keep grinding because you haven't removed enough metal to get to the edge and to raise a burr.
(Speaking of which, I noticed that no matter how much I sharpened, I could not raise a burr. Can you get one with this method?)
It certainly didn't have a bevel line from the factory.
If it's not supposed to have one... how do I sharpen it out? I assume it was due to having too high a sharpening angle?
If that bevel is ok, what do I need to do to get it shaving/scary push sharp?
Also, I've tried stropping, but it seems to only get duller.
Thanks!
-j
Well.
Thanks!
-j
