- Oct 6, 2008
I'd definitely recommend a dark "sulfurized" cutting oil when drilling stainless, but for carbon steels, any handy oil is fine.
Can you explain what the advantage is? When I bought my (admittedly cheap) drill press last fall, I got a small jug of GUNK brand "dark, sulfurized-chlorinated" cutting oil. I use a little pointy-tipped squeeze bottle to apply it to the bit before I drill and keep the bit/hole "wet" as I go. It does seem to work quite well. My bits (also not the best on the market) cut true and stay sharp longer than I thought they would. I'm just curious why it works so well. Does the sulfur and chlorine help with lubrication, heat-transfer, or both?
Incidentally I have used the same press/bits/oil on various high-carbon, tool and stainless steels. Works good on all of them. I have my press running as slow as it will go (620 according to the manual, which still seems a bit fast). I put the steel in a machinist's vice, make sure everything's level and square, and clamp the vise to the table. I feed the bit into the steel pretty slow and back off when the swarf starts to curl up along the bit and spin around. I'm getting good results but I always wonder if I'm missing something... any other tips on proper use of a drill press would be appreciated.
Thanks gents!
