Cliff Stamp
BANNED
- Oct 5, 1998
I do not see reason to do this additional preparation.
I know, that is the problem. I would suggest some basic reading on hypothesis testing and correlation study but you are a mathematician so I am at a loss as to why this isn't obvious to you directly as it is really basic math. I'll attempt to explain it once more.
You are trying to say that the difference between two points is correlated to the blunting pattern, specifically say 150,130,170 and then arguing that the 130 was "sharper" and this is some kind of cyclic behavior. However if you just did a simple monte carlo distribution with a 10 point spread you would get this pattern EVERY TIME with even larger differences.
At a basic level, you need the difference to be much larger than the random noise - of course if you don't know the size of the random noise then you can't make that distinction. This is why determining the noise is as fundamental as the measurement itself and this is made clear as soon as you do any physical science.
I can imagine that yes that sinusoidal pattern is just a noise, but I also can imagine ....
That is why you should do as I have suggested, which I have been doing for years. This way you don't have to imagine anything you can show numerically if your hypothesis is supported or not. I would also not suggest 30 measurements or similar, but rather 3-5 measurements at most and then 3-5 runs so that you have a much more stable result which prevents systematic deviations from being attributed to steels.
-Cliff
