- Jun 4, 2010
As a continuation of experiment capturing images of edge wear that might show distinct patterns, I did a short test with plenty of micrographs. Intent is to demonstrate some amount of predictive analysis by visual inspection of wear (and to see how the Washboard performs as the sharpening media of choice throughout).
Test subject is a Buck 471 in 420HC. A small dig was made in the edge with a utility razor and all subsequent images were referenced to this. Images should be very close to centered on the same region of the edge. Was initially sharpened on 800 grit 3M wet/dry followed by stropping on plain paper with moderate force, approx 30 passes. Edge was three finger sticky and shaved arm hair cleanly to the skin 100%. Images were taken at 400x and 1000x both at approx 15* (bevel face flat to objective) and again at 45*.
Blade was then subjected to wear until it could no longer shave arm hair reliably. Dulling was achieved by cutting endgrain seasoned red oak in 2.5" passes, checking every 20 repetitions - 10 per bevel side. A hefty amount of force was used and edged was pressed and drawn from heel to tip for each cut. Intent was to simulate direct pressure wear and from abrasion vs a hard surface.
After 200 passes the edge could no longer reliably catch hairs but was still doing so to some extent. A pretty good showing. No burring was visible and is assumed proof that the edge was clean and well formed at the start of the test.
A new set of micrographs was then taken as with the fresh edge with an unintended exception. When taking the 45* 1000x image the edge was 'steeled' on the armored tip of the objective as the stage was moved beneath it. Pics were taken anyway - of both sides just to get a good view of the damage and maybe a better understanding of steeling (shouldn't be done at 45*...).
Edge was then subjected to a Washboard with stock compound and one sheet of copy paper. 25 firm passes were applied at approx 16 ozs of force and an additional 10 with decreasing pressure, finishing at 2oz. Additional compound was applied at 15 passes during the repair phase. Normally this is a bit excessive and most edge wear could be fixed with about half as much effort and not re-application of compound, but the damage from the unintentional steeling required extra work.
Resulting edge now reliably tree-topping hairs and was again micrographed (successfully) in all 4 attitudes.
This is the reference nick, all subsequent images taken relative to this mark:
The edge as seen straight from the 800 grit wet/dry:
And after being stropped on plain paper, at 400x 0* and 30* (45 minus the initial 15* bevel angle), and 1000x 0 and 45
ANd now after being dulled - at 400x 0* and 30*, at 1000x 0*:
And now after the 'steeling', all images at 400x:
And now after being recon'd on a WB with stock compound, some edge effect still possibly visible at the site of the inadvertent 'steeling':
Some tentative conclusions:
At least some edge wear conditions can be seen and while taken in a vacuum would not be of much use, when compared side to side with before and after, show the mechanical wear on the edge. I do not believe etchant could be used to show more, but perhaps just comparing from different attitudes could be enough for some predictive or forensic analysis. Would have to be done per steel type and per dulling media - is presumed any changes to either will result in different outcomes.
The Buck Taiwan mfg 420HC outperformed my expectations for durability.
There is no obvious defect in preparing an edge as described initially, edge held up very well.
The WB with stock compound is capable of completely restoring a fair amount of edge wear with no visible rounding of the bevel, and in short order. Displays some of the simplicity and utility I claim as it was a single step from dull 800 grit edge to very well formed 1500 (4k JIS) in under 2 minutes. Edge appears to be clean and burr free. Additional cut test and follow up will be needed to verify but no defect is expected.
Edge wear with this steel appears very straightforward. The edge projections that made up the sharpest portions of the edge appear to have eroded or broken off, following which the added thickness at that point in the bevel reduced cutting efficiency. Additional effects of edge blunting from erosion also visible. Edge wear appears to be pretty uniform.
It is very difficult to get angular images at 1000x. Lighting effects from reflectance and oil immersion may influence the final image but seem to be controllable. The 400x images bring useful info to the table as well, 1000x are preferable.
Is possible that damage/wear characteristics from this sort of test (edge rolling, burring, fracture) could be used to detect sharpening defects not otherwise visible/apparent. More testing needed.
Thanks for taking a look,
Martin
Martin
