If used for food prep while camping, I wouldn't worry too much about rust anyway, with 154CM. Just wipe down the blade after using it. A clean rag or paper towel, moistened/wetted with Windex and stored in a zip-loc bag to keep it moist would go a long way. First rinse the blade with some water, so it's not too grubby before the Windex. Keeping the blade clean & dry will do much more to protect it, and a stainless blade won't need much more than that anyway. A wipedown with Windex is how I usually clean my folder blades (stainless and not) after food use, even when I'm at home. Better than conventional soap & water cleaning for a folder, as there's no worry of getting water into the pivot. It works very well.
The downside to using vinegar to remove rust is, it might help re-create it if the blade isn't immediately cleaned of the vinegar afterwards. Vinegar can break the rust down, but the acidic content will attack clean steel as well, and make more rust. To clean a rusty blade, some baking soda mixed into a paste with water works well when scrubbed on the steel, and the alkaline pH of it will also help neutralize acids in contact with the blade. I use it to clean up carbon steel blades upon which I've forced some patina (using vinegar & water, BTW).
David
