• The rules for The Exchange can be found here. Please read and follow them. Stop using Paypal Friends & Family and follow our best practices to prevent getting ripped off or having a bad deal.
Elephone W3 Smartwatch Mix Business with Pleasure
Feedback: 0 / 0 / 0
Elephone W3 smartwatch features with 1.33 inch color OLED screen clearly displays health parameters including time, date, steps, calories as well as heart rate. Blood pressure and blood oxygen measurement allow you to understand your body better. With comfortable replaceable silicone strap and lightweight feature, you can wear it to do exercise comfortable, such as running, climbing. Elephone W3 shows elegance as well as calmness, making you fashionable enough.
Product Features:
● 1.33 inch Large Colored Display
The all screen design is graced with a 1.33 inch IPS panel with impeccable 240 * 240 resolution.
● Alloy Chassis
The W3 adopts a zinc alloy chassis with beautiful sandblasted finish for everlasting wear resistance.
● High Composite Silicone Material
Elephone W3 is made of silicone composite material of special high-end medical grade. It features a lightweight, breathable and comfortable design that you're willing to wear it all day long.
● Diamond Tough
With 2.5D tempered glass mirror, the ELEphone W3 of excellent rub and scratch resistance is crystal clear and the lustre will always stay.
● Multiple Sports Modes
Built-in multiple sports modes, walking, running, bicycling, rope, skipping, playing badminton, basketball, soccer, and so on, it records a colorful and interesting life.
● Real-time Notifications and Personal Assistant in One
Not only can Elephone W3 receive incoming calls, it will also keep you up to data with notifications, social media updates and more.
● Real-time Heart Rate Monitoring
Elephone W3 supports 24-hour monitoring of heart rate changes. You can adjust your time frame and the amount of exercise you do according to your heart rate curve, which helps you perform better and healthier.
● Improve Your Quality of Sleep
Tracking your sleep pattern and quality with the combination of heart rate monitoring, which helps to improve the accuracy.
● 180mAh Battery
With 180mAh battery capacity as a powerful backing, Elephone W3 can be used for up to 10 days on a single charge (only 3 hours) and its standby time is 25 days.
● Custom Theme At A Tap
Just as you change your clothing from day to day, W3 can easily be modified with custom themes to match your style.
● Other Features
IP67 waterproof, metal for main body, camera remote control, music remote control (only support local player), multi-dial switch, multi-strap to choose.
Four different combinations of dials and straps at GearVita, there is always a will for you. Change with your heart, light up the color of life: https://gearvita.com/elephone-w3-smartwatch.html
Hot sale products:
xiaomi mi box s global version
xiaomi redmi 6 pro smartphone
The Olight S1R II is the second generation of rechargeable side-switch EDC flagship flashlight powered by single CR123A/RCR123A. This extremely compact flashlight reaches an incredible max output of 1,000 lumens thanks to the included new high discharge rate battery. The second-generation TIR optic lens pushes the beam to a new level with unmatched clarity and balanced hotspot.
The magnetic rechargeable tailcap is integrated into a unibody design for a more streamlined and refined look producing a smaller profile. while retaining the classic look of the Baton series, the S1R II features an articulate texturized body pattern that provides a great feel resulting in a firmer grip than the previous generation.
The side switch features a 3-stage color battery level indicator, so you know what battery percentage range you have left in real time. The S1R II also comes with an upgraded MCC2 magnetic USB charging cable that Is more compact and offers a faster 1A charge rate.
Main Parameters:
LED: Cree XM-L2 CW
Max Performance: 1000 lumens
Peak Beam Distance: 145m
Peak Beam Intensity: 5250cd
Compatible Battery: Customised RCR123A IMR
Power Source: 1 × 550mAh IMR 16340
IP Rating: IPX8 (waterproof and submersible up to 2 meters)
Impact Resistance: 1.5 meters
Brightness Outputs and Runtime:
Level 1: 1000 ~ 300 lumens ( 1.5 ~ 37mins )
Level 2: 600 ~ 300 lumens ( 1.5 ~ 45mins )
Level 3: 60 lumens ( 3hrs 40mins )
Level 4: 12 lumens ( 20hrs )
Level 5: 0.5 lumens ( 8 days )
Product Features:
● 1000 Lumens Output
With the help of the all new customized 10C discharge current lithium-manganese battery, the S1R II delivers a huge output of 1000 lumens in a small pocket light powered only by a single IMR rechargeable battery.
● The Pursuit of The Perfect Grip
Small squared texture milling pattern for an extremely firm grip and great look.
● Premium Beam Profile
The S1R II utilizes an upgraded and optimized TIR optic that produces a perfectly balanced hotspot for optimal clarity with an increased light transmission rate of 3%. This produces a soft beam profile transmission that maintains comfortable vision during prolonged use.
● Three-color Power Level Indication
Once the light is turned on, the power indicator located in the center of the side switch shows the power level in three colors (green: power>60%, yellow: power is between 10% and 60%, red: power<10%).
● Highly Efficient MCC II Charger
This new round-edged magnetic USB charger is not only 13% thinner than the previous MCC but is also compatible with all existing rechargeable products (MCC II is not compatible with R50 Pro and PL Mini) with a faster 1A current charging speed.
● IPX8 Waterproof Rating
Rated for up to 2 meters under water without any damage.
● Compact and Light Weight
The S1R Baton II is extremely slim and compact at only 1.8oz/51g with the battery installed. While still easy for a firm grip in any sized hand, this flashlight can also fit in your pocket, attach to a belt loop or backpack strap while barely knowing it's there.
The S1R series is by far the most popular compact flashlight ever produced by Olight due to its incredible output, fantastic design, and convenient features. Get the ultimate every day carry flashlight from GearVita and enjoy the convenience it brings to you: https://gearvita.com/olight-s1r-ii-edc-flashlight-1000-lumens.html
Hot sale products:
xiaomi redmi note 6 pro 64gb
xiaomi mi max 3 4g smartphone
Dacom Armor G06, true wireless stereo headset, in-ear with headband design, closely fits with your ear canal, reduce pressure on your ears and not worry it will drop or fall while doing sports. IPX5 professional waterproof technology, not afraid of drizzle or heavy sweat for exercise any longer.
Product Features:
● IPX5 Waterproof
Protecting from splashing water and rain, protecting from the corrosion of haze and sweat.
● Lower Failure Rate
Dacom sport Bluetooth earphone can be reduce 65% failure rate than general brand.
● CSR Bluetooth 4.1 Chipset
Faster transmission speed, lower consumption, strong stability.
● CVC Noise Reduction with High-definition Mic
More effective shielding background noise, speaker more clearly, HD sound quality.
● Long Time Standby
With 150mAh lithium-polymer battery, the talk time is up to 8 hours, playing time up to 8 hours and standby time up to 180 hours.
● Other Features
Hands-free call, English voice prompt and multi-point connection.
With three colors on GearVita for option, Dacom Armor G06 earphones is a perfect sports partner for you to enjoy running, climbing or driving: https://gearvita.com/dacom-armor-g06-wireless-earphones.html
Hot sale products:
xiaomi lyej05lm
xiaomi mi 8 lite 64gb
Chuwi Hi10 Air Tablet is a cost-effective notebook which supports fingerprint recognition. Equipped with a 10.1 inch FHD display with full IPS screen, brings your photos and videos to life. Powered by Intel Core processor, featuring Gen 8 graphics processor, ensures high performance. 64GB huge hard disk storage brings you smooth using experience. 2.4GHz/ 802.11b/g/n WiFi supported, ensures you high-speed surfing.
Main Parameters:
OS: Windows 10
CPU: Intel Cherry Trail Z8350
GPU: Intel HD Graphics Gen8
Screen: 10.1 inch IPS capacitive screen with 1200 × 1920 resolution
RAM: 4GB
ROM: 64GB
External Memory: TF card up to 128GB
Camera: 2.0MP back camera and 2.0MP front camera
WiFi: 2.4G 802.11 b/g/n wireless internet
Bluetooth: 4.0
Battery Capacity: 6500mAh
Product Features:
● Full Lamination Technology, Holds Glass Closely
Chuwi Hi10 Air adopts OGS full lamination technology to reduce the air refraction between TP and glass significantly, making the picture more vivid. Thanks to OGS tempered glass, the Hi10 Air’s high density LCD pixel is only 0.7mm, creating stereoscopic effect.
● Productivity and Creativity
Hi10 Air perfectly matches with the 10.1-inches soft keyboard, which is connected by docking port. Along with the Chuwi Hipen H2 Stylus, the Hi10 Air provides more comprehensive and effective usage for productivity and creativity.
● Delicate and Clear, Say "No" to Visible Pixels
The combination of IPS display and OGS technology can show colors with unparalleled clarity, 178° viewing angle will give you an amazing experience for watching videos and browsing.
● Solid and Slim, Engineering Aesthetic
Hi10 Air adopts the metal uni-body design which went through 64 manufacturing CNC processes, the extremely thin 8.5mm metal body only weights 562g and makes it suitable for everyday carry backpack.
● Robust Intel Chipset, Fluent Gaming Experience
Equipped Intel's advanced Cherry Trail CPU(up to 1.84GHz) and Gen8 HD Graphics GPU (up to 500MHz), Hi10 Air possesses powerful performance and fast processing speed to guarantee everything to run smooth.
● The Daily Driver for Everything
Hi10 Air comes with 4GB of DDR3L RAM and 64GB eMMC , reading and writing speeds up to 150m/s. With max up to 128GB TF card expandable storage, it meets your needs for movies, games as well as pictures.
● Official Windows 10
Pre-installed Windows 10 OS, Edge browser as well as Cortana will improve your work efficiency and give you the free choice between tablet mode and laptop, great for entertainment and productivity.
● 5V 3A Fast Charging
Hi10 Air fully charges in just 3 hours thanks to USB 3.1 fast charging, and now supports data speeds of 10Gbps, you can charge it with a power bank without carring the big laptop A/C charger.
● Not Only A Tablet
Hi10 Air's keyboard dock brings back that familiar laptop structure required for productivity, the Hi10 Air can also be connect via Bluetooth for wireless support even the Xbox One controller.
If you are looking for a cost-effective tablet, you must not miss it. With the price of $169.99 on GearVita, it is value for money to get a such powerful tablet: https://gearvita.com/chuwi-hi10-air-tablet-pc-10-1-inch-4gb-ram-64gb-rom.html
Hot sale products:
xiaomi mi pad 4 plus 4g
