We have a shipment of Elmax on its way to us.
We introduced Elmax to the North American knife community. It is an excellent steel. However, there were issues with the steel. We told Bohler Uddeholm we would not stock their PM stainless steels until the issues were resolved. Other suppliers continued selling Elmax and did not tell knifemakers about the problems.
We've been assured the issues have been fixed. If this is true we will be stocking Elmax again.
Chuck
Chuck
Chuck
Kind of late the the party, but what exactly is Elmax? I have heard it referred to as the stainless counterpart to hitachi steels, a simple, very clean and fine grained stainless steel with lots of carbon.
The HIP can was the problem. The HIP can is the can the steel powder is put into and then HIP'ed into a billet. The can is 304 stainless steel. After the billet is formed, the billet is rolled into sheets and the can remains on the outside of the sheet. Nathan posted they were removing .010" per side. We found some can to be up to .017" thick. Sometimes the HIP can caused warping during heat treating.
We felt it was not proper for Bohler Uddeholm (BU) to charge for blade steel and require suppliers/knifemakers to remove the 304 SS HIP can. After we found out about the can, we had all the sheets we purchased blanchard ground. We contacted all the knifemakers who had purchased Elmax with a can and replaced it with ground steel. If we did not contact you, you did not get bad steel. Other suppliers were not having the steel ground. We were getting calls from upset knifemakers blaming us for the can when they had bought Elmax from other sources.
We discussed the problem many times with BU. When they refused to change, we decided the issues were significant enough to stop stocking the steel.
Now we've been told the HIP is being removed after the billet is formed. We will see.
Important lesson to be learned is manufacturers and suppliers MUST be held accountable for the materials they sell. We don't expect atta-boys for doing our job. We do expect knifemakers to hold suppliers accountable when they sell bad/non-standard/poor quality/out of spec materials.
Chuck
HIP'ing a can on a billet makes it part of the billet. You cannot peel it apart. It would be like trying to separate Damasteel layers.Chuck, why would they roll with the can still on as opposed to "peeling" it after after the billet is "HIP'd" like us neanderthals do with a can mosaic billet?
Chuck, when you finally get it back in stock, will it still have the can on it? Or will it be clean?
