- Aug 23, 1999
I especially like the wave feature on top of my Commander's blade as it allows me to present the knife faster than any other folder I know of.
I have two complaints so far after evaluating two different commanders (one plainedge and one comboedge).
The first is that after using both of the knives for less than 3 days the blade bolt (which is adjustable) loosened to the point where the blade was extremely wobbly and felt like it was ready to fly off. I corrected this problem by re-tightening the bolt. I have to re-tighten the blade bolt often to keep it from becoming to loose.
Second, this is a result of the first problem, the left side of the blade rubs against the liner lock when opening because of the sloppiness caused by the loose blade bolt. Even when the blade bolt is tight the blade sometimes rubs against the liner lock when opening with the thumb disk method due to the fact that there is a great amount of flex/play, probably from the spacers/bushings on either side of the blade at the blade bolt juncture.
Has any other Commander owners experienced these problems?
