- Mar 12, 2017
I bought the Emerson CQC-7 this week. Mostly because I'm a knife geek and I never quite pulled the trigger on one. It felt like being a knife guy without a CRK.
I "had" to get one to round out my collection and see what all the fuss was about.
Personally, I wanted to see what all the fuss was about positive and negative.
These are my initial impressions:
This thing is a CHUNK of steel. A lightweight comfy Delica it is NOT.
However, I don't think it's intended to be, and as hard use folders go, the knife carries light enough and as agile as possible and stay structurally sound.
The blade is plenty sharp though. This cut was made by placing the forward edge flat against the box and sliding. That is to say, I didn't stab and then pull the blade through like any dull knife would readily do, it is legitimately sharp!
I like the fact that the secondary edge bevel is nice and tall. A lot of knives I've bought, and especially "tactical" folders, have the tiniest little secondary bevel
I guess it helps to keep the edge strong and chip free, but it does nothing to make the knife sharp like it's supposed to be.
I've seen people calling the bevel on the wrong side of this chisel grind, but when you're using the knife in the grip shown here to scrape barnacles off of a surface to set mines on an operation it works great!
(Ernest Emerson cited this as the original idea behind the chisel grind for Team guys),
or in my case: skin wire, debur pipe/ wood, notch things etc. the grind is on the right side.
I guess I'm not thinking of all the things I use a knife in this grip for, but I know for sure I use this reverse grip a lot to scrape, notch, and skin things all the time. Once you get the hang of this cutting grip/ motion with out cutting your self, it's easier to do all kinds of things and I find I have more control with things as simple as opening that irritating clam shell packaging. The chisel grind works really well. Look at Japanese cooking knives! The bevel is on the correct side!
For me at least
The knife is comfy and has a roomy handle with a little space to spare in forward and reverse grips. I don't have long hands or fingers, but I do have thick, beefy, sausage like fingers and hands, I definitely need an ergonomic handle with space and the CQC-7 accomplishes that.
The knife closes easily, no detectable lock stick and has good detent. It's nice and centered as well. The lock up is tight and early with no play in any direction. I was worried it might be a little too early and tried spine whacking it as safely as possible, leveraging the point against a piece of wood, and just plane ole pushing on it as hard as I could and the blade didn't flinch. No play after that either.
I read all the horror stories about a ~$200 knife (Emersons) having super late to the opposing scale late lock up, blade play, and being grossly off center. I can't seem to find any of that with mine.
The wave feature works like a charm if I consciously pull backwards a bit when drawing the knife. If I just draw straight up like I would with any other the knife the wave doesn't engage one little bit and it's business as usual. I find I need a bit of a chunky lanyard to get a secure grip because without the lanyard I'm only getting solid purchase with my not so solid pointer finger and thumb and maybe a bit of middle finger.
With the lanyard I've got my whole fist around something solid and the wave deploys the blade solid and easy.
The finish is a little rough. The scales are a bit aggressive. The clip in conjunction with the rough scales comes out being pretty dang tight on the draw and in slipping back in the pocket. I prefer all these things with the kind of knife it's supposed to be. To me, it's not bad at all in plain jeans and with un-gloved hands. In my experience though, a lot of the things that make an EDC comfy and easy to use (smooth finish, slick and smooth clip and draw, etc.) make a knife slick in gloves and easy to fall/ pull out if the clip snags a piece of rope, air conditioning grill, tool pouch and so on.
I appreciate the "poor" "rough" finish on this knife because I feel that it aids in retaining the knife in your pocket and in your gloved and/ or calloused hand when conditions are close quarters (attics and crawl spaces for me
) and conditions are slimy, greasy, and wet
If these initial impressions are well received by the Blade Forum community, I will comment further on my experiences with the Emerson CQC-7. I'm not going to abUSE it per se, but I will USE the crap out of it over the next month or so for things I don't want to use my Delica for like skinning large gauge wire, installing HVAC units, cutting muddy gritty whatever, scraping stuck things off of other things
basically anything that may take the razor edge off of my Delica or snap it's tip I'll tag in the CQC 7 and we'll see how it goes!
See Y'all later! Tell your Mom'n'em I said hi!
Korean Hog
Korean Hog
