I have the plain 'ol 203 Sharpmaker, but I put a tip back on a friends knife by using the fishing hook groves in the stones. Once it was profiled I went back and sharpened it on the flats. Hope this helps.
Okay, Blades, now you've got me interested. (especially after dropping my Delica and knocking the tip off). Could you explain in more detail how you used the grooves to re-profile the tip? Maybe I'm just dense, but I can't figure it out.
Put the edge of the knife perpendicular against the stone and reprofile the shape to get the tip sharp again (it sounds like Blues used the groove to keep things under control). Then sharpen that part of the blade until the bevels are right. I would then sharpen the whole knife again, so that the edge is even down the length of the blade.
I used the grove to hold it steady and keep it under control(like Paul said). Then I just kept pushing/pulling away till I had a new tip done. It took some work and it's not a perfect tip, but it was alot better when I finished. It probably depends on how much tip is knocked off to do it this way. Hope this helps.
