- Apr 3, 2009
I have 4 complete brass letter/number sets available if your looking.
Lol. Nope, they are listed in the knifemaker sale section.Are you giving them away?
Bill, I had a question about an earlier comment regarding these types of pantographs for shield inlay in the covers. You'd mentioned they can be used for the outline, but not hogging out the interior? Is that correct? So I could use one with a template to do the outline, then switch to a primitive method like Dremel, drill press, or mill to hog out the middle?Yes, they can be used for inlaying if you use the proper cutting tool.
You can use the template with a diamond drag bit to outline your shields, then saw them out.
Hi Bill.Yes, they can be used for inlaying if you use the proper cutting tool.
Gravograph is still in business, I believe and have extensive catalog of their bits. I also see some on ebay searching for Gravograph Cutters, or Hermes cutters.Hi Bill.
I have an IL model Gravograph.
Do you know of a source for long shank end mills for this machine?
All I'm finding is dremel length in 1/16 inch
cutting diameter and I need a shank about 4 inches oal for this machine.
Thanks.
Kevin.
