- Apr 21, 2012
I asked Chris to send me this piece a few weeks ago. It is altogether quite different than the other knives in my collection. For one, it is my understanding that the Ferox was designed with combat in mind, drawing from the maker's experience as a U.S. veteran. It is a large blade, measuring overall length at 11", with 6" of cutting edge. This one is thicker than it looks, with a .21" spine (7/32") of CPM154. However, the spine tapers down to .05" just before the swedge and all the way to .01" at the bottom of the tang. The blade itself is 1.7" wide at the mid-line. This one is slightly blade heavy, balancing right at the ricasso, just forward of the deep grip notch.
At its thickest point around the black canvas pin, the handle is 1.08" inches thick and 1.2" wide. The flat spot shown above makes it possible to rest the knife sideways in the palm, a grip variation discussed here: http://www.moderncombativesystemsblog.com/2016/08/fighting-knives-spotlight-ferox-fighter.html
The knife is a natural pointer.
It is very comfortable in hand, as you would expect from Chris's time spent training with Andy Roy of Fiddleback Forge, and the large rectangular guard and bell-shaped bottom add a sense of grip security, regardless of positioning. The sandblasted micarta and Thunderstorm Kevlar scales are textured, but not uncomfortable, and they do not suffer from the over-smoothing typical with some phenolics.
The supremely tapered tang significantly reduces weight, which comes in at 0.3 kg (10.5 ounces) or .6 lb.
Here is one variation of Osprey Knife & Tool hammering on the flats, which creates a shifting pattern in direct light:
I asked for Chris to sharpen the swedge, which was a good start. I proceeded to spend some time improving it to a true double-edge. The point is absolutely wicked ... I am calling it talonized.
I have made this a triple bevel knife. The straight primary edge is just under 40 degrees inclusive. To strengthen the tip, the sweeping belly of the knife to its terminus is more obtuse and comes in just around 46 degrees. The second grind on the swedge is approximately 50 degrees inclusive. The swedge will slice paper, but is not meant for general EDC tasks. The double edge greatly reduces drag for the sole purpose of penetration and slicing during self-defense (which I sincerely hope is never necessary).
When first holding this knife, I had mixed opinions. However, as I came to think about it from a design perspective, I found I had very little criticism. It is a remarkable application of Chris's vision for this style of blade, and it challenged my perceptions of what a knife should and could be. When you think about the number of talented individuals out there grinding on steel, it is quite a task to make a product that is instantly recognizable and attributable to any one maker. When I look at the Ferox, there is no mistaking the maker, and it is perhaps for this reason that Chris chose it to represent his graduation from apprenticeship to business owner http://www.bladeforums.com/forums/s...Linton-of-Osprey-Knife-and-Tool-has-Graduated
If you are a collector or might conceivably need a blade in this category, I would strongly encourage you to consider the Ferox. If you have one of the few that have been made, let's see it!
