The problem is that some people just don't recognize that different needs require different tools.
"The
sharpening steel and the
honing steel: optically speaking they are very similar and often confused with each other. There is, however, an important difference between these two tools. It is the goal you pursue: sharpening or bending.
The function of a sharpening steel
A sharpening steel removes material from your knife. By moving the edge alongside the steel remove steel to restore the V-shape of the edge. A sharpening steel can, therefore, be used to sharpen knives that have become blunt after frequent use. If you would use a sharpening steel on a daily basis little would be left of your blade after some time, which is fine in a commercial setting where the knives are sent out to be commercially sharpened on a daily basis and rotated with new one frequently.
The function of a honing steel
A honing steel, on the contrary, is not used to sharpen but to restore the bent edge. We call this folding back the burr. You can basically do this every time before you start using your knife. "
Stitchawl
