The Fallkniven. A1 proved itself in the field testing it was time to see what other secretes this knife would reveal in the destruction test. I do not chop in this test because I did it in the first video.
Apple pealing: I was able to remove the peal with ease leaving the apple intact. Then I cut the apple into fairly thin slices. Not bad for a knife with a thick edge.
Batoning: I split a 4x4 in many parts with no problem. Simple for the A1.
Sheet metal penetration: I stabbed into a old index card holder made of heavy gauge sheet metal. After many holes I noticed the end near the tip chipped. This is the fist time this has happened with any knife I have tested.
Cutting 10,000 lb webbing: This gave all the other knives a run for there money but the A1 tackled this easy. I was able to do some very fine controlled cuts back and forth demonstrating it's fantastic cutting edge.
Concrete: Immediately after I started the edge begin to chip out the chips were very shallow. Then the blade begin to dent no longer chipping. It seem the edge is a little brittle. The blade it still intact at this point.
Hammer impacts: Using the 3 lb steel mallet I hammered the edge into a 2x4 repeatedly given the spine god hard hits. No problem here. I then hammered the edge into the concrete removing large sections of the stone. The edge continued to dent no more chipping.
Concrete: again: I hammered the tip into a larger concrete black containing large rock and rebar. Breaking it into small parts. The tip brick of and blunted during this.
Body weight test: This is where we get to see the benefits of the laminated blade. I placed the blade into a holder I made with the blade inserted about 5 inches into the holder. I then stepped onto the knife with all my weight. I weight 225 lbs. I even bounced on it. No blade failure at this point. I pulled the blade out about 2.5" from the handle and stepped on the blade. Again the blade took all of my weight. I bounded up and down for a bit before the blade fractured but it's not over yet.
Metal on metal: The blade was fractured on one side of the outer laminated side. Using the 3 lb steel mallet and hitting the blade on top of the fracture I was able to cut 1/8"x 2" wide mild steel flat stock. I hit the hell out of it with the hammer and the blade still did not separate into pieces. This I am truly amazed about.
Flex text: With the blade fractured I wanted to see how far I could flex the blade in the vice. I first place fracture towards me and pulled with all my strength jerking the blade because it is so stiff. The blade still won't give. I turned the blade around with the fracture away from me and pulled again. After many hard pulls and jerks the blade separated at the laminated sections.
Overall: The A1 performed different then the others. The cutting edge seems brittle but then stops and begins to dent. This is reverse of what has happened with the Carbon knives I have tested. What really sets this blade apart is the laminated construction. A fracture would have totally done in a solid blade but the A1 kept on kicking in a brutal way. The A1 is a fine cutter with it's very easy to sharpen VG-10 steel and convex edge. It did a fantastic job in the field for it's smaller size. All together, you have one serious tough and functional knife all the way around. Fallkniven truly makes some incredible knives.
Whatever hype Fallkniven has amassed, they deserve.
Videos are in 7 parts located at www.knifetests.com
Enjoy the videos. They were made for you. :thumbup:
