Archer Here
- Nov 2, 2008
OUR FEATURED BLADES OF THE WEEK:
Doomsday Boarding Axe -
Designed by esteemed sword tester and designer, Jason Woodard. Based on historical Boarding Axes used by 19th century sailors to chop though doors, cut through rigging and for close combat fighting, with the Axe blade opposed by a utilitarian hook. This hook was used to clear obstacles, assist with climbing and of course, to deliver an armor piercing attack. This heat treated full tang one piece construction results in an EXTREMELY DURABLE and almost indestructible axe.
Total Length = 21 "
Blade Length = 9 ¼ "
Blade Width = 4 ”
Blade Thickness = 3/16 "
Handle Length = 10 ½ ”
Handle Width = 1 7/8 ” Widest
Handle: Black Linen Micarta "
Weight = 2.4 lb
POB = ¾ “ from Handle
Reviewer Jason Woodard's Extreme Durability Test Video Causing NO Damage:
Chopping on trees and old tree stumps. Piercing the pointed end easily through water jugs. Chopping completely through 4x4 Pressure-Treated hard wood. Piercing repeatedly through a 55 gallon steel drum. Multiple Tactical Axe Throws into a door. Stabbing both the tip AND broad head of the axe THROUGH THE HOOD OF A CAR multiple times.
The American Bowie Knife
Total Length = 17 “
Blade Length = 11 ¼ “
Blade Width = 2 “
Blade Thickness = 3/16 “
Handle Length = 5 ¾ “
Handle Width = 1 3/8 “ widest point
Handle: Black Linen Micarta & Brass
Weight = 1.8 lbs
Total Length = 21 "
Blade Width = 4 ”
Weight = 2.4 lb
Total Length = 17 “
Blade Width = 2 “
Weight = 1.8 lbs
