- Apr 21, 2010
I would suggest googling HEMA and either cutlass, falchion, messer, or sabre. Chopping and cutting weapons were prevalent throughout history. Their are multiple systems and weapons designed for this specific purpose.
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
The differences being that sabers in specific tend to have a significantly thicker spine for increased rigidity with strong distal taper and usually deep fullers, often a different curve shape to the point, and a full hilt. This combines to give a much lower point of balance (usually only a few inches in front of the guard) while giving the strength for true blade-on-blade defensive actions without the blade flopping over and yielding to the force involved.
Here's a beautiful example of advanced historical military saber form (Hutton). Many of these actions would not be feasible with a machete either due to balance (timing), lack of rigidity in the blade, improper tip shape, or lack of hand protection.
[video=youtube;DTqeuKW7tHY]https://www.youtube.com/watch?v=DTqeuKW7tHY[/video]
FortyTwoBlades: Yes they are... A Langes Messer as described in Hans Talhoffers treaties is basically a badass machete with a crossguard and nail, and falchion is similar but with a pass through hilt design. The cut and thrust sabers common to western Europe were excellent choppers, often being tested by cutting through a bar of lead, and the guard provided the necessary protection for blade on blade combat. By the way whippy swords are B.S., and as gatka has been mystycized to the point of absurdity I believe that Polish saber is probably a more accurate representation of Western Eurasian sword use.
If you are looking for a more utility version of these tools check out the Khyber knife, long seax, or any of the early European war knives. The problem that you run into with these knives is that they lack any real hand protection, and like the more machete like tools were usually used with a buckler or shield. Because of this they are used more like big knives rather than any true sword.
So he wants to do a little machete fightin', is that so barong?![]()
"The differences being that sabers in specific tend to have a significantly thicker spine for increased rigidity with strong distal taper and usually deep fullers, often a different curve shape to the point, and a full hilt. This combines to give a much lower point of balance (usually only a few inches in front of the guard) while giving the strength for true blade-on-blade defensive actions without the blade flopping over and yielding to the force involved."
1. I recognize that the etymology of swords can be confusing, but I would contend with a Hutton sabre actually being called a sabre. As a later model "sabre" it is closer in design and use to a rapier or spadroon. Sabre (NOT Saber!) comes from the French Sabre which was derived from the Polsh szalbya, was developed as a cavalry weapon, and was used to great affect by the Hungarians, Ottomanns, and Indian militaries. If you look at the history of the sabre you will see that it was primarily a cutting and slashing weapon until it encountered, and was modified by, the more thrust centric styles of central and western Europe to resemble the later Hutton and Patton sabres. Most sabres are balanced far forward of the handle so to emphasize their ability to cut.
Here is a sparring video of the more cut centric Western European (Polish) Sabre
"Notice the "stickiness" Professor Avril (now sadly deceased) uses when parrying. The flexibility of the blade requires it in order to properly immobilize or deflect the other machete."
2. I appreciate the anthropologic value of Haitian machete fighting, but as a practical fighting art it is BS. Parrying has nothing to do with flexibility, although I would argue that blade rigidity rather than flexibility is the key to a good parry. By the way all swords "stick" due to bite of their sharp edges (feels kind of like they're magnetic). The movements of the demonstrators in this scene are in false time->Feet, Body, Arm, Hand rather than in true time ->Hand, Arm, Body, Feet, making the movements slow while providing large openings for attacks. They also fail to acknowledge the importance of protecting the inside line, this would be fatal in a real sword fight for an opponent could then finish them with a thrust or cut in the next tempo. Finally I would say that twirling in a sword or knife fight will get you killed, like boxing the goal of sword and knife fighting is to keep your moves compact, efficient, and effective.
Here is a good demonstration of Langes Messer fencing for comparison
"Whippy swords aren't BS, and were pretty common in India alongside more rigid examples..."
3. Are you referring to the Urumi (whip sword)? These were not very common, and were never really used as battlefield implements. Instead most Indian troops carried versions of the sabre, arming sword, and falchion whose form had been slightly modified due to the variation in culture and use. Similar patterns of sword are pretty much ubiquitous throughout history due to the effectiveness of their design.Weapons were usually popular because they worked, and while whip swords are cool they face many complications when used in a battlefield setting.
What kind of fantasy land do you live in? When/where would you be fighting with a machete?
FortyTwoBlades:
Ah thank you for the clarification. I have heard HEMA practitioners refer to that "stickiness" as "the bind", and I would agree that being able to feel pressure through the blade is an important part of swordsmanship. I don't know if I would refer to swords with a cutting blade with a large distal taper as whippy, for to me they are thicker than description typifies. I think a better description would be flexible or springy. I would also argue that the flat is usually used for a passive parry while edge on parry would be more effective in as it is a more active parry. This is due to the fact that you can apply more force to a smaller area when using the edge, meaning that in a bind or parry where two equal forces collide an edge will always displace a flat. Usually the flat is used more as a passing move, which in the context of the machete is kind of dangerous considering that its lack of guard makes it very unsuitable for prolongated blade contact. A more effective strategy would be to cross cut your way past their guard and use the opening you create to end them rightly.
