If you don’t have coarse diamond or CBN, it is OK to grind bevels of your wear-resistant blade with a coarse silicon carbide abrasive; however, setting the edge apex and honing must be done with diamonds/CBN for the lasting sharp edge. Honing the wear-resistant edge with conventional compounds, including fine ceramic hones, is the main cause of them dulling early – if you use them on your high-end knife, it may perform even worse than a mainstream knife.
We've sharpened premium knife steels both ways, testing the sharpness and edge stability to rolling - and the conclusion is that for the best results, from the #1000 and finer must be diamonds or CBN.
Sorry to say that, but by my experience, what you have is not adequate for sharpening wear-resistant blades.
Moreover, for the best outcome one needs some angle-controlled sharpening method, rather than sharpening freehand on diamond plates.
Todd is the most comprehensive source of SEM images, available on his website
http://scienceofsharp.com. I think Todd knows more than anyone about knife and razor sharpening, and I've learned a lot by reading his comments.
If you re-read Todd's description to the MAXAMET SEM images, he set the edge apex on #1200 diamonds, and honed with 1-micron diamonds.
We do it similarly, but somewhat differently in that, having set the apex on #1000 CBN, we then hone wear-resistant knives with a progression of diamonds from 10-microns to 0.25 microns. E.g. see our detailed protocol in the video
