I have an Ontario SP-2 Airforce knife that I removed the rubber handle from. I purchased a brass guard that fits very closely to the tang (required some filing before I hammered it on and then jbwelded) and a 2x2x6" block of bocote wood that I plan to use as my handle material. I also have two brass pins that I will be using to attach to the two holes in the tang.
Currently the jbweld is curing on the brass guard (with 10 lbs of weight lifting plates on top of it to press it down, the blade is hanging tip down on a cord from its tang).
I plan to drill 3-4 holes into the bocote then chisel out a slot for my tang.
The only question I really have with this is I am wondering when to drill and attach the pins in this process: a) before I shape the wood down to a handle shape b) after the wood is roughly handle shaped
and should I epoxy the the handle on first then drill the pin holes and epoxy the pins in?
Thanks.
Thanks.
