Like others have said, a knife isn't the greatest weapon for self defense. Is pepper spray/mace allowed in your country, state, etc. ? Pepper spray has the advantage of giving you some distance from an attacker.
That being said, another vote for a RUIKE Hornet knife. Good size, RUIKE apparently goes a good job with their 14c28, lightweight, and affordable.
Knives are horrible for self defense, what I consider the absolute last line of defense. With that said, buy something that is easy to conceal, easy to access, durable, and that has a design that helps prevent your hand from sliding from handle to blade.
If you can, I would advise to always de-escalate, walk away, avoid the fight if possible. I also advise to learn and practice using a gun and obtaining a carry permit, of course, if that’s legal in your area. If not some other options, again, if legal in your area, that I think are better than knives are: collapsible baton, OC spray, taser.
Another point to consider, holding a knife can be a negative in a fight, it's like having one hand tied up - you're gripping the knife & not able to use it for much else.
2 well trained open hands will take advantage of this, grab you/your wrist, or enact holds which will instantly remove any advantage a knife may have provided
Honestly, I think we are saying the same thing, just articulated in a different way. The self defense I’m speaking of is basically following the force continuum starting with de-escalation and ending with deadly force. If we are strictly speaking of life or death then my recommendation (of what someone could have on their person in a public setting) would be handgun and then knife. I was using a broader definition or range of self defense, including threats where lethal force is not a necessity. I agree with all of your points, you are correct, I’m just saying there are instances that the less than lethal would be better options. Again, most of this is based upon legality and not my personal preference. Personally, I think that any self defense situation that arises could potentially be deadly and you should be able to defend yourself accordingly. Unfortunately the legal side of things doesn’t agree with me. Hopefully that makes sense.Agreed but I'm not sure about the "better than knives" stuff. I'd put a good fixed blade ahead of any of those as a primary defensive tool, assuming a decent sheath carried correctly. All of those things seem to have much more value as secondary tools and can be good alternatives to deadly force in the right situations. I feel like a primary tool needs to be better at definitively hitting the "off switch" on whatever is trying to hurt or kill me or my family.
I've spent some time training and practicing with batons. Collapsible batons share the deployment problem of folding knives. There is the extra step of needing to extend the baton and that can go wrong. A possible reason to put them ahead of folders is that they don't share the risk of self-injury from deployment failures during a scuffle. Of course, if you do get it out then you do have a slight reach advantage in fights where that matters. There is some overlap between the range of encounters where a folder can be helpful and where a collapsible baton can be helpful.)
OC sprays and tasers will vary depending on how they are set up. Both can be excellent deterrents when used effectively. Unfortunately, there are challenges in using them effectively. They don't always work and at least with the sauce, it can work both ways.
Off the top of my head I don’t know of any horizontal carry sheaths for the Mk1 (of course that doesn’t mean there not out there), but I really like this idea. Imo it’s one of the better “budget” fixed blades on the market and would be great candidate for a custom sheath. The factory one is usable but nothing to write home about.What about a Kabar Mark 1?
