This has not before happened for me. I just got through air quenching a full tang blade and the foil packet lost all noticable air pressure very soon after lowering into the wind tunnel. I mean the blade looked like it was vacuum packet in the foil. I could even see the plunge lines !!
I do not know why this happened except that it is obvious the air within the packet was thin and hot. There are two things I did differently on this packet: I only folded the edges twice instead of my usual three folds AND I left the packet extra long to keep the hard folds away from the blade end and tip (warp stuff, you know). A inadvertant pin hole does not make sense because that would allow cool air in, so it must have been air tight in the cool air but I wonder if the 'only two folds' allowed some of the air out during time in the oven.
There is no noticable decarb or scaling. After cutting the packet, pulling the foil away from the blade was like pulling good tape off. It was stuck like tape. Oven temperature during HT was 1965 F.. Soak was 25 minutes.
Anyone else have this happen?? I just knew the blade would come out twisted and warped but it did not (thank God) and it sure seemed to quench good.
Roger
Roger
