- Jun 10, 2016
LC200N looks like a great steel. It's on the well rounded side, maybe corrosion resistance being really high. Ok.Because ceramic knives aren't really knives.
OP, your answer is lc200n.
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
I've got that same opener. Did you ever do the Tac Pro sniper match in TX? (that's where I got mine)
No that pic is just grabbed off the net.I've got that same opener. Did you ever do the Tac Pro sniper match in TX? (that's where I got mine)
Any good quality blade with a thin blade geometry would murder limes with ease. Keep it cleaned and dried after each use, and a good carbon steel will develop a nice patina from the lime juice, however don't do that and you will have problems...
Any quality stainless like 14c27n, Aeb-L, n690, vg10, cts-xhp, ELMAX, all the way up to m390 or cpm110v if you want better edge retention will work fine.
That's just it... I guess I'm learning which of those 3 I needed most... for cutting 99% limes 1%lemons and orangesHeavily edited after I re-read the OP.
The combination you're looking for doesn't exist. Pick which of those three you need the most.
Best balance all the way around? Probably 20CV/M390/204P.
- Most corrosion resistant: LC200N or Vanax. Ok toughness and edge retention.
- Best edge retention: S110V. Ok corrosion resistance but not great toughness.
- Best toughness: AEB-L. Good corrosion resistance and decent edge retention.
That's an excellent point. There is that metallic taste SOMEtimes if I didn't wipe the blade after the previous use. I do love carbon steel, but as strategy mentioned there's a great list of those newer stainless steels that do have a lot of the required attributes. Maybe I should have put a poll up listing some of the obvious steel candidates. I'm no stranger to pen and paper. Cast your vote! If i can create a poll post-post then I'll do that tonight. Kid's waking up from a backseat nap.As a user of carbon steel kitchen knives I would suggest stainless for lime specific duties. As lime juice accumulates on the carbon steel while batch processing limes the juice takes on a dark hue which can be transferred to subsequent limes ruining the presentation.
Fair question. It's not for my yearly Corona (beer). I bartend a crazy busy bar... well it used to be. We're working out the new outdoor setup and business is, well still slow but picking up. Last year I would probably cut 100-200 limes per shift. Alway in a hurry. As a knife geek I suppose I'm searching for that ideal knife.How many limes are you cutting that it requires a specific knife?
Winner winner chicken dinnerDUH! Smatchet!--KV
In that environment, Victorinox 47556 5" Serrated Chef Knife with Fibrox Handle. It's small, stainless, low maintenance, won't hurt your pocket book when one of the other bartenders uses it to pry open the cash register drawer than hasn't been used in 6 months. It's not sexy, but it's the right tool for the job.
Napalm... you must know the scene because that scenario is spot on. I've literally done that exact thing more than once. We have 2 noname serrated POSs and our good one, which i bought, a Wusthof 8" bread knife (the smallest one). It's the 2nd one we've been thru. The first was mine until I upgraded to the 9" double serrated, which was pretty sweet. Even had a custom sheath made. What i didn't like was the long sawwing motion. When I'm really crankin on limes, I wanted to minimize movement. I cut a dime sized disc flap off my thumb with that 9" Wusthof. The samuraistuart thin knife was a huge improvement. For limes I've found that Sharp plain edge > serrated > less than sharp plain. Serrated wins for consistency. But again... the long push-pull sucks.when i consider questions, as such asked by the OP, i think of "mamas kitchen" growing up, what did she use?
she used a kitchen aid serrated knife with partial tang, black plastic handle, stamped china, what "we" consider to be epic POS's, and still to this day she still has that knife floating around somewhere, and do you know what? still cuts limes just fine, so an answer --- any serrated steel will work fine, if you want to light-saber melt through a lime for some reason then any serrated knife from henckels, shun, global, or wusthof will do, i think they use ice-hardened german stainless. this is just my experience, but i would recommend that whatever you choose, make sure its fully serrated
I suspect you're correct.I predict that your current knife by samuraistuart will be hard to beat, but check out what he has is S45VN is you are ready for an upgrade: https://www.bladeforums.com/threads/new-crucible-s45vn-hunting-knife.1751295/#post-20031753
