- Dec 27, 2013
I've had the pleasure of working a few knives in a relatively new alpha-beta titanium alloy: ASTM grade 38, called ATI 425 by Allegheny Technologies Incorporated, the company that introduced this alloy in 2010. Among other uses (such as parts for the current Mars rovers), it functions as armor plating for military vehicles.
Continuing on with the snub-nosed knife shape:
The wrapped grips are recessed into the tang. These were forged and ground thin:
Grade 38 is interesting because of it's high iron content, which is a strong beta phase stabilizing element when alloyed into titanium, and also brings a potent deep-hardening effect into the mix. Iron disperses into very fine particles within a titanium matrix.
Grade 38 titanium chemical composition:
Compared to good ole' fashioned Grade 5 (6al4v), you can see that alpha stabilizer Aluminum was reduced by a third, and beta stabilizer Vanadium was reduced by half. Iron was then introduced to around 1.5% which is really high in a ti alloy, and produces interesting results during heat-treatment.
They started by shredding a bunch of teeth off of a new band saw blade cutting tabs from the armor plate:
Here they are ready for experimental heat treatment:
In keeping with the military hardware theme, a spent 105mm Howitzer shell was used as a quench tank. It's amazing that in a matter of seconds, quenching one of those thin little blades turns the whole reservoir of ice-cold water, filled to the brim, lukewarm including the brass itself. Yes, that is a USAF 105 shell! Crazy, right?
This alloy proved to be very heat-treatable has some fairly exciting potential for blades. The thin knives took a keen, fine edge. I like it. More must be made...
Thanks for looking. :]
