JTknives
Blade Heat Treating www.jarodtodd.com
- Jun 11, 2006
Ok this will be the build thread fallowing the fabrication of my press. All the steel is right in the way in the middle of my shop so i have to start cutting it up and assembling it. This press is rather tall at 8ft. but this allows me to use the long ram i have and and lots of clearance between the dies. the dies are 16"x4" with nothing sticking up to get in the way. Thy lock into place with pins or threaded studs. then a nut or shaft collar will hold them in place. As it sits right now I have 16" between die plates, this does not including any dies I weld onto them. The bottom die plate sets at 32.5" off the floor. The uprights are spaced 4" apart so I can come in from the side to straighten billets. Coming in from the front I have a 8" wide opening between uprights so i can use what ever width of dies I like. i was going to make this even wider but it did not fit the material i have on hand. Plus the die plates would have to be much longer to use the mounting system i designed. Im going to start cutting these parts soon so if you see a problem let me know. the clevises on the cylinder will go inside the upper support tube and lower die assembly. These tubes have a 1/2" wall thickness and are quite beefy. the upper tube is 8" tall and 4" wide. the lower one is 12" tall and also 4" wide. I also made the side guides so thy bolt into place. This allows for adjusting as well as removing the upper die assembly if needed. I hate having moving things trapped in place by welds. Thanks guys.
P.S. Not including the cylinder and casters this things weighs just over 900 lbs
