- Feb 7, 2000
I've broken a lot of folders.
Really? How?
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Im sorry if I offended you or something, I guess I just wasn't very clear.
I wasn't saying that strength completely doesn't matter.
What I was saying is that if an important knife buying decision was based around lock types you shouldn't let supposed strength keep you from buying a knife you like.
In most normal use a knife is forced against the back spacer, lock bar, stop pin...ect so you shouldn't be in danger of one folding on you unless using your knife in an unsafe manner.
Now as far as strength goes, I have more confidence in a lock bar than a stop pin to well stop my blade.
Not to say that lock bars fail all of the time but they are much smaller than a much larger lockbar.
Tests normally seem to test how well a lock holds a blade open which may be their job, but what they need to test is how much Force it takes for a knife to fold backwards which is the direction a blade is forced during normal use.
I may be wrong, but I think a stop pin might fail before a back lockbar in most cases.
The frame lock is stronger and easier to maintain. But, neither knife should fail if you use it correctly, because you should never use a knife in a manner that loads heavy stress on a mechanical latch. For that kind of work, you should be using an appropriate fixed blade.
n2s
The biggest strength of the framelock is your grip reinforces the lock.
What is a good quality reasonably priced framelock knife to introduce someone to them?
Charlie, do you think that's true for a LH user as well? I enjoy my frame locks, but I've always noticed a clear RH bias in the design. This has never stopped me from using them effectively; I can close all mine one handed, no problem. But I wonder if the LH user grip would reinforce the lock position in the same way as RH.
I'm definitely with the Triad lock crowd. This should get 'er done.
http://www.coldsteel.com/4max-2017.html
I strongly dislike backlocks, they're difficult to one hand close. Frame locks are just so much easier. I actually really like liner locks, though many of my knives do not have liner lock. As mentioned, my folders are not under a great amount of stress, so I don't have to worry about the lock failing, and quite honestly liner locks are significantly easier to disengage. So I really prefer them.
Really? How?
