- Jan 10, 2018
That was a very strange but somewhat informative video, thanks for sharing!I think it is a toss up! Check out this video of 180 lb standing on slabs of both materials.
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Thanks for the insight. Just out of curiosity, why was G10 used in the threaded/tapped applications as opposed to carbon fiber, and are there carbon fiber equivalents for the same application?You won't see any difference in the two in any knife application. Even in extreme blatant abuse.
Make no mistake.....g-10 is incredibly strong and durable. I have dozens of jigs, fixtures and tooling and replaced/repaired steel parts using g-10. I've used it in tapped/threaded applications and it is ridiculous how much torque can be applied to those threads with no damage or wear even after years of repeated use.
So pick what appeals to you and don't give it another moment's worry.
Because g-10 is easier to machine, cheaper and comes typically in a wider range of sizes.Thanks for the insight. Just out of curiosity, why was G10 used in the threaded/tapped applications as opposed to carbon fiber, and are there carbon fiber equivalents for the same application?
Carbon would winFor a knife handle scale, which is tougher, which is stronger, which is more resistant to impacts, chipping, and deformation? I've searched around the various threads on this topic, and have yet to find anything definitive. The conversations seem to always steer toward which material people favor, and more or less conclude that both are simply strong enough.
My main questions:
1. Suppose you have 2 slabs of equal size, G10 and CF. If equal pressure were applied to the middle of each, which would break (not just bend) first?
2. If both slabs were dropped from the same height (say, 20 feet) onto concrete, which would suffer the most damage?
From what I've read, there are different types of both material. I suppose for the sake of this thread, I'm asking about the average G10 used on knives, as well as the average woven carbon fiber used on knives (if there even is an average woven CF composition, I don't know much about CF.)
Edit: If there is a big enough difference between the various possible compositions of both, as some suggest, then what about the strongest/toughest G10 vs the strongest/toughest carbon fiber?
It broke my hammer!Good plan. Let us know how it does!
Isn't simple curiosity reason enough ?![]()
