Hey all,
Total knife noob and long time lurker here based in Seattle and finally decided I had a question worth posting. I'm generally pretty handy and have most of the right tools for this hobby so I've decided to try my hand at a pair of chef's blades in AEB-L (for Christmas gifts no less! We'll see about that timeline...).
I got the blades profiled and handle holes drilled out and started my heat treat using the following recipe:
SS foil wrap.
1750F for 10min, plate quench.
1975F for 15 min soak at temp, plate quench.
Remove foil.
Dry ice/isopropyl slurry for about 2 hours.
Snap temper at 320F for 30min (ran out of day to finish temper)
Currently working on the final tempers now, 2x 350F for 2 hours each. This is more or less what I've seen around for AEB-L, but i noticed one thing with many of these HT recipes that's missing and that's ramp rates, i.e. how quickly the oven can get from one temperature to a (usually) higher temperature.
I only notice this because I have a fairly small HT oven with a small 1600W element (limited to 120V). It seemed to me that when I opened the oven to put the blades in, the temperature would drop almost 300F and take a significant amount of time to get back up to 1975F (15+ minutes). Add this to a 15 minute soak once to temp and it would seem to me that these blades have been at high heat for too long? I may be overthinking this since the blades are not even done with temper yet, but it got me to thinking, what is a normal ramp rate for HT ovens and how can one compensate for slow ramp rates if the oven is not capable for fast enough ramps?
Sorry if this was a bit long winded, but is there any way to save these blades if I have over soaked them at high temp? Thanks to all for any help you might have.
SS foil wrap.
Remove foil.
