Mods will probably move this to Maintenance, Tinkering, and Embellishment, but anyhow..
Your best bet is to remove the thumbstud. From there you can hold it on the flat section or face of the blade (primary grind). The face would probably be the most stable, but just remember the angle will be set a lot higher than the true angle you're sharpening at if you do it that way. If you're just trying to match the angle of the existing bevel it wont matter much though. Also if you have strong neodym magnet under the blade table it will also help hold it in place without wiggling around.
