The classic example is a German military knife with a trigger and a blade that slides out the front (OFT).
When the trigger is pulled as the knife is held vertically, the blade can drop down and lock in place by gravity. No springs are used in the knife. Bring the knife up , pull the trigger and the blade drops back into the handle.
Another example (subject to interpretation) would be any knife in which the blade can be opened without touching the blade and with out the use of an activating device, knob, button, etc..., only gravity.
I modified a Buck 110 and a Schrade LB7 years ago by reprofiling the blade heels so that they could be flicked open quite easily. This could fall under the definition of a gravity blade depending on who saw the knives in action. I usually explained that they were "worn out". They were carried in vertical leather sheaths ( Dukes of Hazzard was big then) otherwise they would open in your pocket.
Both my Spyderco Military and Dodo have been modded to preform in the same manner without really changing the knife, just polishing and tweaking the action/lock.
