Cushing H.
- Jun 3, 2019
My guess is this is mostly directed at Stacy....
There is a couple-year old thread related to this, which does not quite answer my questions. For reference (but not to necropost) it is here: https://www.bladeforums.com/threads/usuaba-grind-w-radius-platen.1514532/
So .... questions are as follows: in that thread, stacy refers to creating a (I think) radiused sanding backer by creating a certain length fulcrum, attaching it to a piece of wood, then sweeping back and forth on the grinder to create a certain radius. would that technique work well enough to create a wood radius platen for use on the actual grinder?? (obviously, this would be a seldom used thing .... otherwise a metal radius platen would be better. Second - would such a wood platen work well enough if just secured directly onto the grinders brackets - OR should it really be placed on top of a flat metal platen (with appropriate counter sunk screws to hold it in place)??
Then .... when it comes to actually grinding the urasuki, what do you do..... start with the outer radius of the radius platen basically centered on the back of the blade .... then work the grind until the concave grind just touches the edge???? or do you take another approach?? (if you start at the center, here is where the parallelogram grinding setup Stacy mentions would be really useful .... unless once you get the hollow started gives you the same "feel" as does freehand grinding a flat bevel.......)
