- Nov 5, 2004
Howdy,
I've got a buddy that wants me to make a bowie for him. It's not a conventional bowie however, as it has a finger grooved full tang blade. Being a rather large bowie, it's neccessary for it to have a guard on it. Unfortunatly, I'm beat as to how to get one on. I've attatched a rough sketch to better explain my question.
Part A. shows the handle of the knife from the side without any handle scales. The shaded part is the actual tang. Part B. and C. are looking at the finger grooves and the spine, respectively. Again, the shaded area is exposed metal.
Due to the design, there is not enough metal to create a guard out of the tang and place a bolster over it. Because the handle and blade are almost the same width, how do I get a guard to go on and stay on?
I considered slotted guards, but I'd prefer a double-sided guard, so that's kinda out.
Thanks for the help!
~Brian
~Brian
		 Another idea might be to split the top arm of the guard, spread it out and then press it back with a hydraulic press and braze or weld th seam.  One of the smiths, maybe Bruce Bump, says that he gets a tight fit on his guards with his press.  If you are going with a full tang for "stength" you can also go with the "3/4 tang" like a Randall Model 14 where the top is exposed and you slide the handle on from the bottom.
