gruntmedik
- Mar 12, 2009
One thing to keep in mind with the handgun, is familiarity. If it something that your family will only use in an emergency, or just the occasional range trip, I suggest a 4" 357 Magnum revolver. They can also shoot 38 Special, and can be loaded with light target loads, up to 180gr hunting loads. I suggest the revolver mainly due to immediate action drills. With a revolver, if it goes "Click" instead of "Bang", simply pulling the trigger again will introduce a fresh cartridge under the firing pin (provided it is fully loaded). With a semi-auto, there is a specific procedure that must be followed for it to be rendered operational again. If it isn't something that is practiced regularly, the outcome could potentially be devastating.
If you do choose to go semi-auto, I suggest going to a gun shop and handle as many different handguns as possible. Find what is comfortable, and go from there. S&W M&P, Glock, SIG, FN, HK, CZ...etc, there are many to choose from. One word of advice--before you decide, look at the price and availability of extra magazines. Some are far more expensive than others.
For the shotgun, a 12ga pump is the gold standard. If you have left handed family members, a Mossberg has a safety that is easily accessed by either hand.
For a centerfire hunting rifle, a bolt action 30-06 or 270 will do anything that needs to be hunted in North America. I chose those 2 calibers, as a few years ago when the big ammo crunch happened, they were consistently available at my local Walmart. 223, 5.56, 308, 7.62 were as scarce as duck teeth. Ruger American is a great low cost rifle, as is the Savage Axis. Top it with a quality 3-9x40 scope, and you have it covered.
A plus to going with the 357 Mag, is lever action rifles can be had in the same caliber. 44 Mag too, for that matter.
You can't go wrong with a 10-22.
