bdmicarta - I did all the work on a 2 x 42" craftsman sander/grinder. It goes really really fast. Thats all I have made my knives and handles with so it takes some practice when you hold the scales on it or even touch the wheels to it. The highest grit I went when contouring the scales was 120 grit. You don't need to go get anything higher than 80 if you don't want to, it just takes some extra elbow grease. The drum sander bit and the little barrels are worth the $15 - $20 you will pay to get the bit and the different grits. Just make sure that you move back and forth and don't create little divots into the tang.
As for how I angled the fronts. I did it all by hand with the flat platten. This picture is close to what I do, but since I don't have anyone else in the shop to take pictures while I actually do the work, it is kind of a little off because I could show only with one hand on the scales and one hand on my phone.
If you have a little table like mine does that angles you could use that and just use a test piece of wood to see how deep it will go into the scales depending on which angle you set it to. If not practice by hand on some scrap wood first. I drew the lines to where I wanted it to stop and then I just angled the scales and followed back and forth the contour of the front of the scales carefully not going over the line or the bottom edge of the scales.
I believe that it is really important to plan out a knife build. Trace the black on the paper. Put in where the bolts/pins will be, and then draw in the front and where the angled front will stop. Go as far as even drawing contour lines and shading it if you have to. Make everything to exact size on the paper. Side views, top views, bottom views all of it. It is some work but it will help you make sure your knife turns out what you wanted it to be compared to just going at it.
The only reason I did not do that for this W.I.P thread, and I probably should have, was because I already knew what I needed to do based on what I have done in the past.
Does that help? The questions are good. Thats what this thread is for.
