Bigfattyt
- Jun 23, 2007
I looked up Drakes channel and seen the tutorial it was pretty good but if I want to refine more after aligning the burr with the rough stone I don't break it off until I am done with the finer stones right? For example lets say 400 grit diamond to make the burr, flip the side to make it even then proceed to something like 1000 or higher and when I am happy break the burr?
Is 1000 grit really all it takes to shave arm hair on D2? I will check out those stickys but I don't have enough knives to invest too much into a high end system maybe eventually though.
You should be able to shave arm hair with a 200 grit, or 400 grit stone edge.
I have taken D2 to shaving sharp on a sheet of automotive sand paper. 400 grit.
D2 has large almost plate like carbide (under high magnification). Diamomd stones can be had pretty cheap.
