- Jun 11, 2006
The time has finally come for me to build a heat treat oven. I have been getting by with my pid controlled forge for many moons and it has served me well but it's time for an upgrade. I have pulled design elaments from lots of deffrent sources and combined them into one super Franken-oven. The bricks have been ordered and the steel is being cut to shape as we speak and will be picked up tomarow. If when you read this thread you see something funky and off let me know as I don't have time for stupid mistakes.
Features:
1: Fast heating is a must, being that I do one blade at a time I don't want to weight an hr to come up to temp.
2: Paragon style door. I love the non latching counter weighted door that can be opened and closed quick.
3: Smart controller, the controller must be able to save programs and be able to recall them at the touch of a button.
4: Smart argon injection, the oven will have a shealding gas setup that will monitor the O2 level in the oven and inject argon to counter this as well as keep the O2 level low through the entire heating cycle. Can be turned on or off with the smart controller that controlles the ovens heating.
5: Long elament life, the guidelines followed in the kanthal book to a T
So as you can see I got my work cut out for me. But there has been a lot of planning and prepping for this build so everything should go smooth. Let's start off with the ovens size. The heating chamber is 5.5"x5.5"x27", one big driving factor to the size is the 25" long D2 planer blades I get that need annealing. I would rather anneal them in full length so I can use them as needed. Below is the solid model of the oven drawn up to this point. Today or tomarow I will sketch out controller box location and a few other things. But is allowed me to fit and fine tune all the metal parts as I'm having them cut for me.
At fitst I was planing on doing grooves in the side for the coiled like everyone else does but then in my research I came across another way that actually gives better life and allows slightly higher surface loading.
This is coil over rod and then hung from the ceiling. The coil is wrapped around a rod that is hung from the roof of the kiln. In researching this even further I discovered a variant to this which is coil in tube. The coil is wound and inserted into a fuzed Quartz tube. This tube is then hung from the roof. I'm going back and forth on weather or not I'm going to do coil over rod or coil in tube. I like the coil in tube idea because the coil is complety shielded from outside contact. Going this route will eliminate the grooves in the side walls which I'm hoping will help keep the oven shell cooler. The cover page of kanthal pdf has a picture of coil over rod.
In my drawings you can see I have it drawn for coil in tube. The tubes or rods would be cut to span the 5.5" width and set in pockets.
Running the coil on the roof in a zig-zag faction allows me to use much more wire which allows me to up the wire gauge and amps and still keeping the surface load between the recomended 3-4watt range. Still playing with the coil design currently and have not decided yet on a gauge yet but I'm guessing I will use 12-13gauge and 20-25 amp load.
The controller I'm going to use is the TAP controller. Right now it's only found on new kilns. This controller is not made by even heat but the manufacture is not selling to the public currently so I had to find a way to get my mitts on one. So after much research I decided to just get the upgrade kit from Tracy at USAknifemakers. the TAP might look expensive but if you buy any other good quality PID that can store programs and has USB input you will be starting at around $800 was the cheapest I could find. At first I was worried as it says only for ramp master upgrade and that it was just adding features to the current control. But after studying the schematics it's apparent that the TAP controller is a complete pid set up wether it's an upgrade or as us, thy are all the same. The upgrade just has the adaptor harness to allow a plug-n'-play set up.
After tracking down the PDF on how to do the upgrade I can easily see how it's wired up and it's nothing special.
Here is a nice shot of the TAP controller. Just standard plugs so the upgrade is just a wire harnes to plug into the old control harnes.
Then to make sure there was nothing special hiding in that big red even heat box I tracked down a wiring diagram for a oven with and with out a TAP controller and thy are the same.
Also thy where kind enough to list the pin outs for the TAP, so now I'm ready to rock and roll.
The great thing is thy have all the part numbers for everyone on the drawing so I looked up the relay and the transformer and thy are just standard items which will be very easy to aquire.
So that's it for right now but I will have some build pictures very soon as I pick up the metal tomorrow.
But my buddy and I are currently working on the O2 sensor and control board which he has and is programming. In a nut shell the O2 controller will get a signal from the TAP controller. You might be wondering how this can be done. Well I'm going to tap into the alarm output on the TAP controller.
When programming the TAP it will ask if you want to set an alarm at a set point. I will just consider the alarm on or off as O2 control on or off. so I can have the oven warm up and once it hits X temp or X time it will turn on the O2 control circuit which will then start injecting argon and monitoring the O2 level in the oven and hold it to a set %.
So thanks for giving this a read and if you see any major flaw let me know. Thanks guys.
Features:
