- Mar 21, 2020
Hi all,
I have very recently tried my hand at knife making, my 1st attempt was a piece of 1080+ flat stock 5mm thick, I made my own version of a bushcraft knife, I watched a lot of videos on you tube and so I had the basics in mind for heat treating, I managed to get a hold of a devilforge and got the blade to non magnetic fairly quickly, quenching it in warmed rapeseed oil (uk version of canola as far as I have been told) using a cutting motion and it turned out fine, no warps, no cracks. I was delighted. This has since turned out to be a massive dose of first time luck. Project number 2 a chef knife for my better half, same steel although this was a bit thinner 3mm. Heated to non magnetic (I am new to this so I fear I may have overheated) quenched in the rapeseed oil in a cutting motion and it came out with a noticeable bend. I am aware using thinner metal and possibly keeping it in a bit too long may have been my down fall, my question is this, this happened yesterday and I got a little dis-heartened (1st time blues I guess) so I left it for the night to think about my options with it. I Am keen to get back out and sort it today, my worry is that I have left it to cool overnight. So it will still b Brittal, I know I still have to temper before I attempt to straighten, but I thought about putting it back in the devilforge heating back up and quenching again and try straightening it back up before it gets too cold, Will this work? Or if not should I try clamping it up is such a way that straightens it then put in the oven for its tempering cycles? Or have I fucked it all together by leaving it overnight. Any help or advice would be very much appreciated.
Thanks in advance
Dave
Thanks in advance
Dave
