I have a question regarding the temperature used when quenching to achieve certain hardness. I have search on the Net and unable to find information about this.
If you quench steel bellow non-magnetic temperature, would you achieve a level of hardness above the non heat treated steel. For example if the starting HRC of the steel is 30, then you bring the steel (80crv2) to 700 C and then quench, would the hardness increase to say (45) HRC instead of the usual HRC of around 60 when done properly at 850 C. Can you choose what hardness to achieve through pre-quench temperatures? or does this need to be done through tempering.
The reason i ask i because i am making swords from 80crv2 but because these swords will be blunt training weapons that will be struck against other blunt swords often, the desired end HRC is 47-50.
Due to the limitation i have for tempering a large piece of steel (700-900mm) to 400+ C in order to achieve the desired HRC of 47-50. I thought maybe a sub optimal hardness for a sharpened weapon may be achievable via low temp quenching. I realise i may have this concept completely wrong and wondering if hardness can only be achieved at above non-magnetic temps.
