JT, that's really interesting. Are you clamping your blades straight before they have cooled down to MF, or at least before it's come all the way down to room temp?
I'd personally be a bit afraid to clamp a warped blade, even simply clamped straight without any counter bend, if it had already completely cooled down.
Either way, clamping it straight between two bars before it reaches MF, then allowing it to finish cooling in them, and then keeping them clamped while going through its first temper cycle seems like it could be a good (and extra safe
) way to go about.
I'll have to try this on my next warp, as the current blade I working on, after I had tempered it once went through probably another 5 temper cycles while clamped with a counter bend at the apex of the warp, and it did NOT want to straighten out at all. It pretty much stayed the same even though I continued increasing the counter bend after each cycle.
So I ended up bringing it back up to about 415F once more, but this time I took it out while it was hot and used a "three-point" straightening jig in a vice, which was finally what got it to straighten out (enough). It really took a surprising amount of counter bending to get it to straighten out, though!
~Paul
My YT Channel
Lsubslimed
(It's been a few years since my last upload)
