- Nov 26, 2001
My work of transforming pounds over pounds of fine steel into useless dust continues...
Ok, I'm exaggerating... I just tried to grind two knives: one started as a tanto-style about 8" long and is now miniature-size (and still wrong). The other is a bit better, but has the edge mis-centered and the spine all wrong, perfect on one side, wobbly and overground on the other.
I know it's not much as an experience, but I feel I have a definite problem and that I can't progress with it.
I can't get a decent hollow grind. It seems I can't maintain straight pluge cuts or a constant height of the spine...
I followed Hrisoulas' advices without any result. In the end It seems to me that I have a problem with the pressure I exert against the wheel. I'm using a 10" wheel, 2.5" wide.
I start with a 80 grit, then go to 100, then 200 and 400.
I try to get the shape as good as possible with the 80 and then to refine it with the finer grits, but I always mess everything up.
When you grind do you press firmly the steel against the wheel?
Do you keep a very light touch, the steel lightly touching the belt?
Does pressure vary with grit?
Any trick to have more constant, true to the belt pressure on the blade?
Please help me... don't let me destroy other fine steel...
I warn you! I have hostages! I have two bars of syntherized ATS34! I'll grind them! I'll do it!!!
Thanks for any tips.
