- Mar 4, 2016
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
No, but it has a good reputation and it should meet all your criteria. Unless you abuse it then it will last with reasonable care.Interesting looking thing! Do you have one?
Kuhkris are heavy chopping knives meant for different tasks than a machete - chopping wood vs clearing brush and grasses.
I met a surveyor once who said he had used practically every machete over several decades and he recommended old Collins Legitimus machetes as the best. They can be found on eBay.
As for a good sheath, you can search the internet for one after you have the machete. Marbles and Rothco make inexpensive sheath that have pouches for other gear.
As for sawbacks, unlikely on a CL but you could add it with a file or hire someone to do so.
You will have to decide if you want something for cutting smaller stuff or something pretty rigid for essentially chopping. If I owned one machete, it would be the 18" Condor El Salvador with the wood handle. They are a tad expensive running about $80 US with the sheath. But unless you loose it, you'll be using it for a long time.
Most machetes are made with a steel that is more apt to bend rather than chip if you hit something hard.
A 14" or 16" machete is easier to carry on your belt. Shorter than that length, you are probably better off with a big knife for versatility.
From what I gather it's a WW2 era machete? Very interesting, nice to hear a real expert opinion too.
I think 16 or 18 inches is more along the lines of what I am looking for. I do want to use it for chopping and batoning.
I like the standard Golok too (have two of them). It is THE machete that started me on the Condor path. I have since moved to the El Salvador and Swampmaster for most cutting that I do. I need to thin the handle down (sand) just a tad on the Swampmaster. My hands aren't huge..... My favorite mid-sized machete is the Golok. It is long enough to be effective on thin grasses, but really shines at de-limbing. It just blows through thumb-sized branches. It has a convex grind that throws chips like an ax on thicker stuff. Cutting down trees is not its forte, but I have used it to take down five- and six-inch Chinese elms.
I'm am not sure what sort of cutting you will do, as a machete and khukuri cut differently. But, If you are in the Netherlands, I would look at the Skrama from Verusteleka in Finland.
