Yo! I think it kind of is a consensus.
HehGuy enters bar swinging. I'm not going to argue semantics with a total stranger. What a way to troll.
I have a 1x30. I've had it for about 10+ years. I don't really recommend it for most people.....
I've used it on knives in the 1k range, but it is super easy to absolutely destroy your knives. They are high speed, no changing speed, and they are a bit more "bouncy" also.
I think having some form of power tool to reprofiling or correct is necessary even if you want to freehand. Freehanding hard stainless that is severely rounded off or changing the angle is a very time consuming activity especially if your just starting. And then you need something to reprofile bolsters as well.I have freehand Norton India stones, and a Sharpmaker... but the sharpener that let me do all the things I wanted to do like reprofile and repair, is the Work Sharp with the Ken Onion Blade Grinding Attachment. Plus a strop and good to go for everything with minimal mess or liquids.
I'm trying to decide too. I want a hair whittling, mirror edge on my s30v blade. I looked at the WE Go model, but it doesn't include a lot of stones I need for that price. I haven't compared the KME yet, but the EP looks suitable. Would the KME be a better choice?
If I had to do it over, I would clamp a stone holder in an angle vise.
The Aluminum bar stock, from which the stone shelf is made, is 1/2”X 2 1/2”. Just cut a 2 1/2” piece from a bar, rotate it 1/4th turn, and screw it to the back of the long piece (clamping across the sawed edges won’t be as smooth or square). The shelf lip is made from 1/2”X1/2” stock.Any advice on how to do this, since the jaws on most angle vises don't open wide enough to accommodate the entire length of the stone holder? If the jaws moved parallel to the axis of tilting then it would be no problem as you would just be clamping the width of the stone holder, but all the tilting vises I've seen have the jaw motion perpendicular to the tilting axis. Maybe clamp a small piece of plywood and have the stone holder rest on that and against the moving jaw of the vise?
Knock yourself out. You can adjust the angle to 0.1 degree with an angle cube.
