- Feb 27, 2011
My K-bar 1221 held up very well, although I have more difficulty honing & maintaning a sabre-grind (I'm a long-time fan of buck-110's. Thus, I'm very skilled at honing hollow-grinds, sabre-hollows, etc), & due to this & possibly the softer-steel, I couldn't keep an optimal edge. I can generally put a razor-like edge on any
knife & it will hold, & in all fairness, my 1221 held it well enough. Both the tang & blade were strong. 440-A, I later learned, is a softer steel, much like & similar to
in composition to Aus-6. This may be the likely reason it was able to handle the throwing & the fact I rarely missed (on the occassions I did, though, I lost the pommel, chipped the edge, & point--rocks) The pommel broke off rather easily, which irritated me (although it did do a number on my little finger!) A Sog Seal Pup (original) .165 (3/16th) would be the same thickness & generally same steel as the 1221. Would it be as tough as the 1221? Yes, more than likely. Would it be as able for chopping, hacking, pruning, battoning, splitting, hammering, absolutely NOT (Whichwere, btw, chores I chose the Ka-bar 1221 specifically for, & chores it absolutely excelled at.) (I recently handled & examined a Sog Seal Pup & found it seemed to be a stout little knife). I've also seen the *exposed tangs of all the Seal Series (past & present) & in being fair I will not lie--the tangs are just as substantial as the 1221's. Do I like the 1221 better--absolutely, I know it in & out. Also, in being fair:the 1221's tang was infact, as thick as the blade's spine, smooth, clean, there was no soldering, it was all one single, solid piece. It was also about 2/3rds of the blade's width & that is QUITE a substantial narrow-tang!)
(I believe the 1221's pommel broke due to the lanyard hole sticking out, it seemed to create a point for pressure to focus. I bet if it were for those little lanyard holes, that problem would be resolved).
*When I say 'exposed', I don't mean the little bit showing on the Elite versions--I mean INSIDE the handle. They're done much like the 1221--as thick as the spine,
as long or longer than the handle, & 2/3rds or a little bit more of the blade's width.
Bored-2-deth.
Bored-2-deth.
