Thanks i Will Check if it Is Parallel.Yup that’s what I was referring to. If those are off it can cause some tracking issues.
I think ive seen a video of youre setup on YouTube, could be? Looks great.Here's a couple pics of my grinders tracking controls... Thought they might help.
yes you are right, and bearings as iddler wheels is geniusCrown your tracking wheel, flatten your idlers and you should be good to go.
maybe i could try a stronger springAlso, try more tension spring pressure on the belt.
My specs are 1500r motor, 7 inch drive wheel. In the video im at 50hz that would give me 13-14 m/s, seems kind of low . 75-80hz would get me to 20m/s.Hot bearings is not normal. I use bearings for idlers, it was temporary solution but here I am, year later. I usually work with belt speed at 20m/s @50Hz, sometimes if I feel the need, I turn VDF to 75-80Hz, which gives me 30m/s (almost 6000sfm). At that speed bearings are louder and start to get hot. Not that I can't touch them, no. I know that there are variations in the same size, dirt cheap bearings usually have lower speed rating. Item names may vary, depending manufacturer, but high speed bearings is what we want.
Searching online these are the specifications of the bearings im using. I dont know if theyre ok or not. Can you point me which bearings Will be apt for high speeds with those measurements?If the bolt is getting too hot to touch you may be overheating the the wheels. This may cause them to warp which will cause your tracking to go cattywampus. You should probably go to high speed bearings. They aren't that expensive.
This3,14 x 0,047 x 20000 / 60 = 49m/s. If my calculations are correct, these bearings can withstand almost 50m/s speed. Looks perfectly fine to me to use even bare, like in my grinder setup.
Another reason for bearings to get hot is if they are under tension. Not load, but side to side tension. Do you have sleeve between both bearings, inside that grilon wheel? Is it repurposed part or did you order it to someone to make it? That sleeve (or calibrated tube, or what is it's name) is designed to interference fit, one bearing shoulders against the wheel, another just floats, for lack of better name. When you torque that bolt, then bearing inner races and sleeve is what is being torqued. Bearing outer races and wheel have interference fit. That is, if you have that sleeve. If not - there are torqued preload on all bearing and heat from working.
here is a picture of my wheels assembly3,14 x 0,047 x 20000 / 60 = 49m/s. If my calculations are correct, these bearings can withstand almost 50m/s speed. Looks perfectly fine to me to use even bare, like in my grinder setup.
from right to left is, BOLT - WASHER (ONLY TOUCHES INNER RACE) - BEARING - GRILON WHEEL - BEARING - WASHER (ONLY TOUCHES INNER RACE) - LOCKING NUT - PLATTEN - LOCKING NUT
i dont have anything inside of the wheel between the bearings, i think i understood what you mean but im not sure, i need to put a turned cilinder between the inner races of both bearings inside the wheel?
here is a picture of the wheel without bearings, i bought them separately and pressed the bearings on the cavity. i torqued the assembly with the locking nut just until it moves freely with no play.
they are like that right now, just tight enough to keep the assembly together, if i lossen them just a little bit it rattles.Inner sleeve needed.... Yes. Or just make sure you are not over tightening your nuts.
Just for an experiment, loosen them so they are just snug. Tight enough to keep the assy together. Run it again, is it Hot?
first of all thank you guys for taking time for helping me.
i would try to make some inner sleeves then, the bolt axle is 20mm, i have steel tube lying around 25mm outer diameter - and 21mm inner diameter, if i cut it the same lenght that of the space between the bearings inside inner races would that be ok? or the inner diameter of the sleeve would need to be exactly 20mm?
