You going to a convexed near zero?I made one similar to what you are after (13" blade), out of 3/16" CPM 3V. I had Peters do the HT to 60 RHC. I followed Scott Gossman's suggestion to do a flat grind for 70%, then convex. It was fairly easy to do and ended up very sharp.
Could be overkill for baby carrots, but it worked well for 2x4s also.
A number of years ago at the Guild Show in Orlando, I talked to a couple of the guys who had pioneered the "cleaver" style competition cutters made from CPM M4 and the forward mounted lanyard. They said that they would take them WAY down until they failed and then sharpen back until the it worked. IIRC, they said that they could get them down to around 15 thousandths behind the edge and still have them survive.
I bought some 3V as well .300 (I think) but the I found out that it isn't ideal for a real comp chopper so it will get made into a couple of crazy trail choppers after I get them down. I thought A2 was a nice compromise of price and performanceYou want to use stock at least 1/4” thick. The pros use stuff .300” or even thicker. You want a lot of material to work with. I like a long full flat grind to near zero on mine.
That's Nathan's Stuff though. Its kinda a thing of legendThis thin works on Nathan's D3V, I was amazed how thin it was when I got it
~Chip
Someone I'm not sure who(maybe Big Chris) said that with the thin edges 3V would sometimes stretch at the edge.Who said that 3v wasn’t ideal for a comp cutter? I imagine it wouldn’t work as well as M4 at holding a super thin, acute edge(which would be used for the precision cuts, like straws, paper, etc...). But it would work great for shopping.
For a “cheaper steel,” I know a lot of competitors are using 52100. It will take a super fine edge and is pretty tough. I got a comp chopper blade blank from Jose Diaz in .320” 52100. That could be an option for you. My plan was to make a few comp choppers to refine my design, and THEN make one out of M4 or Bohler Vanadis 4 Extra.
