For now they are exclusively available on the rickhindererknives website.Where did you find these? VERY interested...
I put some CRK fluorinated grease on the washers. Maybe that wasn't enough.Maybe you need a drop of lube in the works?
I bet you have the pivot to tight, trick is to find the sweet spot just when the blade is centered and then use a small drop of blue locktite.This weekend I swapped out the caged bearing for the pb washers. Centering is still great, but it went from rocketing open and smoothly drop shutting, to needing a wrist flick to open consistently and not drop shutting. Is this solely a need of washers to break in, or did I screw something up?
I didn't touch the lock bar stabilizer. Just disassemble, remove bearings, add the spacers, add the pb washers, then back together.I bet you have the pivot to tight, trick is to find the sweet spot just when the blade is centered and then use a small drop of blue locktite.
If you want to use washer go with the teflon washer rather than PB
Bearings are OK but they are noisy and almost sloppy feeling , to me anyways. All of my Hinderer are on teflon washer .
Did you change the lock bar stabilizer?
It would be MUCH cheaper to Rit dye the orange scale to black, or just about any of other darker colors.I loosened the pivot a touch, and it was a much smoother opening. Still not drop shutty, but that probably just takes break in. In either case, I swapped back to bearings so I can have the extra smooth action now. I work in an office, so it's not likely to get gummed up. If I take it out on a hunting trip or similar adventure, I'll drop the washers back in. These really are easy to disassemble and reassemble. I think I'm actually gonna give this one some pocket time. (Along with a small sebenza 21 in a sheath as a backup knife.)
Now my only sadness with it is my orange scale gets discolored super easily from my jeans. I know a magic eraser makes quick work of it, but still. I want to get a second scale for this in black.
Orange is my favorite color. I want to have the option for both.It would be MUCH cheaper to Rit dye the orange scale to black, or just about any of other darker colors.
