Hey guys, I have some old pieces of labeled wood that were given to me in 2006 by an acquaintance who was a knife-maker. They've been sitting in a barn since then. My parents recently found them and said "do you want these?" (hah!) These pieces include: Gum Box Elder HackBerry Cherry and a large unknown block! I found an old forum post that said Cherry, Gum, and Box Elder need to be stabilized. Not sure about HackBerry. Is there a way to visually tell if the gentleman who gave them to me had bought them stabilized? Thanks, J. Keeton
THe large brown piece is either Brazillian rosewood or cocobolo. Sand a small piece of it, if it smells spicy it is cocobolo, if it smells rosey it is brazillian. Sand a piece of wood you think might be stabilized. Most stabilized wood dust is very light in color, almost light. It also has a distinctive slightly sweet smell to it.
What other stabilizers are used besides acrylic .If it's just been sanded different stabilizers will have different smells
One say to check wood is to see how it floats in water. A well stabilized wood will either sink, or float with just the top barely clear of water. If the wood floats high in water, it's not been stabilized. Of the woods listed by OP, the Box Elder is the only one that will almost sink, the Gum, Cherry, and Hackberry will float with over half of wood out of water unless it's been stabilized. The blocks labeled Gum, Cherry, and Hackberry look like they're spalted, and if so I'll bet they've been stabilized.
I agree, the simplest way is to sand a place to 400 grit and hit on a buffer with white polish. Stabilized will shine like glass ( almost). Some natural wood may shine, but not as much.
The Gum and Hackberry sunk like rocks. The Cherry and Box Elder floated, but with 95% of the block under water.
Epoxy thinned down is often used, (it's also a common part of g10 etc) It's really easy to tell if it's fresh, the smell is hard to get rid of... but all epoxy is not the same, not by a long shot, more chemicals involved than in steel formulas; ) https://en.wikipedia.org/wiki/Epoxy (so many variants it's not really fair to call all 'epoxy') this is one reason I dislike stabilized wood... and would rather use a strong natural closed grain hardwood, like ironwoods epoxy certainly can be strong, but I'm really just sick of all forms of plastic
I cant think of any stabilizers who use an epoxy based stabilint. A key property is that it can be injected into the wood and then hardened, epoxy is mixed with a harder so you are battling the clock. all stabilizing companies I know use either use an acrylic that is forced in under pressure and heat cured, or a poly-ethelythene polymer dissolved in strong solvent, but this often causes wood colors to run so blocks stabilized in this way are almost always dyed.
Yep, I agree with Stacy - Gum and Hackberry are stabilized with the box elder being natural (doesn't need stabilizing)..... say 99.9% assured? Ben has Boxelder listed as "another soft wood that is often stabilized" - Ben is MUCH more qualified to comment on the need of BoxElder to be stabilized than I am. The blocks of (edit to remove Boxelder) Grey Box Burl I have do not seem to be stabilized, but are very dense and hard and float like your block does, about 95% (or more) under water. What I have isn't truly BoxElder like Ben has, but is Grey Box Burl. Sorry I had it all wrong - my memory just isn't so good. Ken H>
the stabilizing of wood usually uses MMA https://en.wikipedia.org/wiki/Methyl_methacrylate which gets sucked into the wood under vacuum, then cured at a bit over 200F I treat all of these organo-esther-plastics as plastics, and epoxy's part of the family imho .. I'm guilty of just heaping all of those different esther type chemical polymer plastics together. ... I've seen it where actual epoxy is injected into larger voids in burls etc, after the wood has absorbed a MMA bath (which doesn't fill voids)
All my box elder burl gets stabilized. I would not think of it as a dense wood. It is very lovely when stabilized. It is also one of the few woods that does well with the double-dying process. I have never seen wood stabilized with epoxy, only MMA. The colorful stuff you see lately with filled pockets and edges of burl caps is filled after stabilizing. I think most of it is done with alumilite, like Masecraft uses.
Some confusion results from the similar names of boxwood (very dense and hard) and box elder, aka Manitoba maple. I have box elder growing all around me, and it isn’t much harder than poplar. It’s softer than walnut.
Sorry folks, I just checked by box of wood and the "Boxelder" I was referring to is NOT Boxelder, but Grey Box Burl. It is a heavy dense wood is from southeastern Australia. "The burls grow on medium sized trees in the Eucalyptus family. The density generally ranges from .83 up to 1.1" - that's why what I have isn't stabilized, but is nothing like BoxElder. I stand firmly corrected. Ken H>
