Imagine your knife as the bow of a boat pushing through the water.
#6 is a complex grind that I am working on right now.
However, I take issue with the idea that a hollow grind displaces better.
...you have to be concerned about the material passing over the entire blade.
Woodcarving/whittling and convex edges are like peanut butter & jelly. A hollow grind will "bind" in your cut causing you to either fracture (cut out) your cut, or worse, damage your blade. A flat grind does much better than a hollow grind - hence the widespread use of puukkos for carving. However, a slight convex edge makes woodcarving a true joy because it cuts easy and is easy to keep sharp.
I had a 22" long khukuri that with a flat/slightly hollow 2nd bevel chipped out large pieces of the blade when I used it on 1.5" branches. I took that exact knife and without changing the heat treat or anything, reground a new convex edge on it, and was able to go through 5" logs without even so much as rolling the edge.
Does convex edge = just the edge bevel...
On the whole, a convex edge is tougher, regardless of the thickness of the steel, compared to a hollow or flat grind.
Sharpening a convex edge is easier.
It is true that many tools have hollow grinds or flat grinds to help them be more efficient, but this discussion is about knives, not chisels, adzes, etc.
The AK Bowie in the first video I posted is heavy and thick and yet it cuts material better than other, thinner bowies because of the convex edge.
My Campanion chipped,before my convexing,but also after the convexing.
...can you have a true hollow ground edge?
... the flat ground blade oustrips the hollow-ground by at least 10 to 1.
Originally posted by Cliff Stamp
As a dramatic example, compare the toughness of an Opinel (convex), to an old style Strider WB (hollow) (or one of the Busse fat varients if you want a really lopsided comparison).
V-ground edges with secondary edge bevels are in general much easier to sharpen than convex bevels...With a x-coarse primary stone, you can remove visible edge damage in 1-2 minutes...The secondary edge bevel is then applied pretty much instantly as noted so total sharpening time is 1-2 minutes. This is a complete honing, not a minor touchup, and includes removal of visible damage. Try the same (without power equipment) on a convex bevel and see if you can come close to the time with similar abrasives.
With a convex bevel you are limited by a smaller contact area...
And a splitting axe (full convex grind) chops no where near as well as a felling axe (hollow grind).
What is the relative edge thickness and angle (and heft) of the other bowies. Of course if the convex bowie has a very high shoulder resulting in an effect a much thinner edge then it cuts better.
To be specific lets assuming you take a Trailmaster from Cold Steel and put in on a slack belt and apply a wide convex edge. It now cuts much better, considering the initial edge is ~25 degrees, you can cut the shoulder down to 8-10 and thus pretty much raise the cutting ability to double on shallow cutting and the chopping ability would go up to 50%+ or more. Now does this mean convex grinds are superior. Of course not. The same thing would have happened if you applied a wide flat relief grind.
Knife Outlet :
On the disadvantage side, the main one is sharpening time. Convex bevels take much longer to sharpen than dual v-ground bevels due to a *massive* increase in contact area. A dual v-grind has a secondary edge bevel <1 mm wide, a convex bevel can be ten times this wide easily which means that much more metal needs to be removed for each and every sharpening, even for minor touchups. The inherent speed difference is vastly magnified when a v-rod system or something similar is used to set the secondary bevel, the time difference can now be 100:1 .
-Cliff
Many of my customers are chicken-boners and they would go through a 5" semi-flex curved boner on average every 6 weeks.
This is more about steel type and thickness than about edge geometry...
This is why convex edges on benchstones are not recommended. The key is a conforming material backing various grits of sandpaper.
Many felling axes come with a final convex egde put on after the hollow grind.
As stated before, if you strop, you are "convexing" the edge whether you want to or not. Simple as that.
The point is that even with a spine that is a hair under 1/2" thick, you can still slice fine paper, chope wood, cut leather, slice carboard - all with a convex edge.
a multi-bevel edge can do nearly (probably imperceptibly) everything a convex edge can do - except that it's harder to put on and maintain
The solution was to apply a heavier secondary edge bevel which had a more obtuse angle. This clearly showed the obvious point that you can not ignore thickness and angle and just generalize to convex is stronger than flat.
Yes, this does allow them to be sharpened with less skill...This of course means that convex edges require specialized equipment to allow honing to similar speeds as flat grinds, this makes them less versatile and of course much slower when the *same abrasives* are used for both compared to secondary bevels on flat grinds. It is always easier to grind or cut flats as it is curves. [emphasis added]
If you want to be really anal about such distinctions then all edges are convex...
1. Paper cutting performance is just influenced by edge sharpness.
2. As to the other media, since leather, woods and cardboard all exert binding forces to various extents, the thickness of both edge and spine of the knife come into play.
3. That knife will be *vastly* outcut by a flat ground SAK on all those types of materials (assuming you are cutting and not chopping), as the SAK will wedge less since it is much thinner.
4. This is why Stanly knives (and other such blades used by tradesemen and for craft work on exactly those types of materials) are very thin, and flat ground for ease of sharpening. [numbers added]
As explained in the above a multi-bevel edge requires less skill (to grind/sharpen) and is more versatile in required equipment... (parentheses added)
To bring out the origional points, much of the benefits attributed to convex edges are not due to them being convex at all but due to other properties, specifically:
1) the cutting increase and durability gains are from an increased shoulder and final edge angle, the same would be gained from a secondary bevel system first popularized by John Juranich of Razor Edge
2) the ease of sharpening is simply due to the lower angle tolerance when using a soft media, this can also be achieved using a secondary edge bevel and a v-rod (the latter can be setup by eye with benchstones, no equipment required).
