Hey Frank...
What kind of pad you use makes a huge difference too..
As well as the amount of pressure you use...
I'm using a custom made 2 ton press,, so your mileage will vary...
Yaa if you are using a guardless Mora,,then she's gonna roll on you..
you have to hold it horizontal to your mould more than likely..
It will leave a cavity after time..One pressing shouldn't leave much of a mark...
However different factors will play into that..Mainly pressure, and type of pad you are using.... how hot your plastic is and how long you leave it in will also effect it...
5-6 pressings is pretty bad mileage to be quite honest...However type of knife will make a difference as well...
All depends on what I'm doing....
I get sometimes 20-30 sheaths All depending on what I'm doing and how much I'm paying attention...
I've forgotten a knife in the press for a few hours..The mould is pretty battered then,,and I'll only get a few sheaths off it...
On small folders I've gotten close to 100 pressings...
I press in this order..
Flat knives, small knives, med knives, large, then folders, and then other things like lighters ect ect...
Thats when I'm doing a run.... I always try to do a run if I can,, that way I've got some different knives to work with...
As well the more your mould is burnt out,, the more rolling you'll get the more you have to hold the knife horizontal...
It's hard to explain,, but I can look at my mould and know what it's still capable of doing....That comes with experience is all.... If you are pressing just for yourself and not in production,, you may not get to the point of being able to read them like that....
I've been using a new foam, because my suppliers were out of what I normally use, and I really don't like it...I'm use to what I like and know what I can get out of what I like...
also used the neoprene from knife kits and that stuff is pretty good..I've been told it's hard to burn out,, however I'm using part of one right now for a foot rest on my desk...I don't find it worth the cost or hassle to order,,however you may have Excellent luck with it.. worth a try for you....
ttyle
Eric
O/ST
