Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
- Aug 20, 2004
These are the instructions I use to get someone started with a profiled stainless steel knife blank. I send it to new makers when I send them a blade blank and handle kit.
I thought there might be those who could use the tutorial and pointers. Some details are specific to a particular knife project, but the info is universal. You can start with a bar of any type of steel and shape it to the knife profile you want. 1084 is a good starter carbon steel, and CPM-154 is a good starter stainless steel.
Files needed are a 10-12" mill bastard (or a magic-cut), and a 10" second cut file. A finishing file is nice, but not necessary. Here is a great file and filing tutorial - http://www.appropedia.org/Filing_Metal
As to the paper, use wet-or-dry metal working paper in grits from 100 to as high as you wish. Most folks use it in steps of roughly doubling the grit. A good set would be, 100/220/400/800/1000/1500/2000/2500. Buy the best paper available. 3M or RhynoWet are both good. I am posting this in two parts.
Part One - Basic Instructions:
The knife:
I have preformed the knife shape to your template. The handle scales will be rough shaped and drilled to accept the Corby bolts. When you get the knife, unscrew the bolts and remove the handles. Take a look at how things fit for reassembly later.
Let's get the names of all the parts clear.
The end of the handle is called the BUTT.
The two pieces of wood are called the SCALES.
The attachments for the scales are called RIVETS. The type of rivets I am supplying are called CORBY BOLTS.
The flat area directly in front of the handle is called the RICASSO, and is the space between the end of the bevels/cutting edge and the handle.
Any inward curve or indentation at the ricasso area or ricasso end of the handle is called a CHOIL.
The little rounded notch at the end of the sharpened edge (at the ricasso) is called a SPANISH NOTCH
The top of the blade is the SPINE.
The cutting part is the EDGE.
The taper from spine to edge is the BEVEL.
The end of the cutting edge and bevels is the PLUNGE LINE.
The handle area above the ricasso is the TANG. There are several types of tangs.
The taper from the ricasso to the tip (looking down on the spine) is called DISTAL TAPER.
The point is the TIP.
Work area and procedures:
Find a place where you can safely work on the knife and have room to move. A picnic table outside will work, or any small work surface in the garage. Don't use the kitchen table or the resident cook may become upset with you.
If possible, screw or clamp a strong piece of wood so about 10 inches sticks out from the corner of the worktable. This is the sanding arm. A piece of 2X4 will work. The knife is clamped/screwed to the board, with the edge just off the wood, to allow sanding and filing. IF you curt the board to match the shape of the blade edge it makes filing much easier.
File with smooth strokes in one direction only. Never file in a back-and-forth motion.
When sanding, cut the paper into strips, and use a two-inch-wide by six-inch-long block of hardwood as a backing block. I cut 8X2" strips and use a heavy rubber band to hold the ends on the block. Get a small plastic tub or something that will hold about a quart of water for when you do the wet sanding. You will dip the block and paper in the water. Sand in one direction strokes. Most sanding should start at the ricasso and progress toward the tip. The initial sanding can be perpendicular to the blade (spine to edge) but the finer sanding should always be parallel to the blade ( ricasso to tip). When changing grits in the coarse to fine range (50 to 400 grit) change the angle of each grit so you can tell the old sanding lines from the new ones. Don't move to a finer grit until all the scratch lines from the last one are gone. It is very hard to get them out later. They have a nasty habit of showing up again as you get to the fine grits. If you see a deeper scratch.....stop....and go back at least one grit until the scratch is gone .... then proceed back up the sanding steps. Skipping grit sizes is not going to speed things up. Progress from the coarse grit to 400-800 for the pre-HT sanding. In final finish, the finer the grit, the better the blade looks. The rule of thumb is to double the grit size (more or less) each grit change. That would roughly be 100,200,400,800,1000,1500,2000,4000,8000. When doing the final sanding some people sand dry to 800, then wet sand to 8000. I generally wet sand all the time. With the 3M polishing papers (the multi-colored pack) wet sanding is not as necessary but works very well if you go that route. Wet sanding will give you a brighter and shinier final finish. Save the 3M papers for final finishing after the HT. They are super for getting the handle sanded and polished. When wet sanding, clean off the blade, the block, and change the water in the tub at each grit change. The sanding water should be - a quart of water, ½ teaspoon dish soap, 1/2 teaspoon of baking/washing soda. More on sanding later.
Getting Started:
Mark the blade tang with a marker where the handle ends at the ricasso. When working on a blade, don't sand or file any of the metal that will be under the handle scales, or the wood may not sit flush with the tang when reassembled. This is a common error, and often shows as a little space where the handle comes down to the ricasso. Avoiding it now is how to keep from having to deal with it when you start to assemble the knife and discover that the ricasso is curved up under the handle a bit. By marking the handle area, and not doing any sanding/filing there, you will assure that the area is still flat when you finish the knife after heat treatment. Some folks tape this area with masking tape (the blue painter's tape is what I use), to make it clear that there is to be no work done there. That is a good procedure to learn. I often tape any part of a knife that I am not currently working on - the handle area when doing the bevels or the blade when working on the handle, etc.
Decide how you want the blade to be beveled, and where the plunge line should be. For this blade, I suggest a full bevel - from edge to spine - and the plunge line about 3/8" to 1/2" in front of the handle. A good trick to keep the plunge even and straight is to clamp a piece of steel on the blade at the plunge to guide the file and act as a stop. Here are special made File Guides made from carbide for this task. It is a good investment when accumulating equipment.
Screw or clamp the blade to the board. Clamp the plunge guide on the blade at the ricasso. File the bevels in slowly. Take a little off at a time, easing up on the final shape. Flip the blade and work the other side regularly, allowing the shape to form from both sides. Don't try to do one side and then the other. That takes a lot of experience, and gives many old smiths trouble.
Stop each step before it is fully to the point you want. Look it over carefully before taking the final strokes of the file. It is easy to take a little more metal off later, or to go back and change the shape, but impossible to put any metal back on once it is filed away. Also, don't file the bevels to a sharp edge. This is one of the most common errors. Leave the edge a fairly wide flat surface. About the thickness of a dime in the filing stage (.040-.050"), and half the thickness of a dime after sanding before HT (.020-.030"). Always remember that the next step will take off some more metal. I suggest filing to 80% shape, sanding to 95% shape, HT, then final sanding to shape. The last step after the handle is assembled is forming the edge secondary bevel and final sharpening.
