THanks much for that Sylvester. Actually just testing some of the newer stuff right now. Well, right now just got out of shower, but have pice ready for cutting and grinding next to me right now as soon as I finish waking up.
First off, while the thread is actually on stabilizing wood, there are some very good posts on resins/etc on this thread at CKD:
http://ckdforums.com/showthread.php?s=&threadid=14288&perpage=15&pagenumber=1
I right now am actually just using the regular fiberglass resin that you can find at Home Depot. IIt's a styrene monomer, and gives you a bit more working time than lots of epoxies. It works better if you thin it a bit with some acetone or another thinner, as discussed in the above thread.
If you are making it from fabric, I'll make a few suggestions from things I've picked up. If you try this resin and don't thin it, you willhave some problems with fuzzing, where the resin doesn't completely impregnate the fibers of the fabric. This is helped by thinning. Also, fabric that is 100% cotton works a lot better than fabric that is part synthetic(ie polyester, etc). If you are using a patterned fabric, get it with a small pattern. Ie, some of my camouflage micarta, I used plain fabric where biggest sections of colors were maybe half an inch across, and other batch I used regular BDU's where you had stripes an inch across or more. You need the smaller pattern to have the different colors come out when the micarta is ground.
Other options which also work better for paper based micartas are some of the thing epoxies used for golf club or fishing pole making, or B72, which is a resin that you get in pellet form and dissolve in acetone. I haven't tried either of these yet, but there are many makers here who use the B72 for stabilizing wood with good results, and there was at least one maker, the guy who first got me intersted in making my own micarta, who made paper baesd micarta with thinner epoxy(pretty sure he said it was for making golf clubs). If you search back a while ago(almost a year now) in this forum you can find his work, though I don't remember theusers name. Had some striking micarta that was layered with black and bright yellow.
Anything else, let m eknow.
Oh yeah, forgot to mention you will have some problems with bubbles too with the resin I suggest. A superglue finish afterwards takes care of this, but thinning should take carte of a lot of it too(one of things I'm testing on this latest batch)
